  • Replies 18.9k
  • Created
  • Last Reply
Top Posters In This Topic
Thanks for this service. New boxster owner needing a radio code.
Becker cdr-220
model BE 6625
serial # 25014141
Appreciate it
joe
Try 0872
Thank you so much. That was it.
Loren. New old car and replaced the Battery. Thank you thank you
CD-R-210
Model R3297
Serial W5023142
Thanks again.
Thanks for your promptness even on a Sunday. (Wow) Unfortunately code didn't work. I double checked the Serial Number and tried every code from 4140-4160. Any thoughts? Thanks again.
Did you obtain the serial number using the procedure in the Lost Radio Code FAQ?
If not, then please do so and re-submit.
I did and just to be sure I repeated again. Same serial number. The system is a CDR-210 and not CR-210, but the instructions worked.post-99876-0-69149000-1421607122_thumb.j
I did and just to be sure I repeated again. Same serial number. The system is a CDR-210 and not CR-210, but the instructions worked.attachicon.gifimage.jpg
It should be 4150 - so it looks like you will need to contact a dealer or Becker -- sorry.
Hello, my name is Chris and I'm completlety new to this forum.
To be honest, all I'm trying to do is help out my friend that bought his 1999 Porsche 911 Carrera.
He disconected his battery and doesn't have the code for the radio.
It is a Becker,
Model# BE2282
Serial# V5008233.
I hope someone could help me to get the code for him, help is really appreciated.
Thank you in advance.
Chris
It is a Becker,
Model# BE2282
Serial# V5008233.
Chris
Try 1352
It is a Becker,
Model# BE2282
Serial# V5008233.
Chris
Try 1352
Thank you Loren for your fast respond, but it did not work.
It is a Becker,
Model# BE2282
Serial# V5008233.
Chris
Try 1352
It is a Becker,
Model# BE2282
Serial# V5008233.
Chris
Try 1352
I'm sorry for the confusion but my buddy was to dumb to hit the enter button after he typed in the code. It is working now.
Thanks again
Hi, I'd really appreciate your help looking up my code.
Becker CDR-220
Model - 4462
Serial # Y5038894
Many thanks,
Jools
