  • Replies 19k
  • Created
  • Last Reply
Top Posters In This Topic
Loren,
Please provide the code for my CR-210, Mod# 3297, Ser# W5011585.
Thank you very much,
Hank
hi  have a 99 boxster radio needing code it is a becker with the flip down cd doortype 4462 x5017498 48/98...any help would be super appreciated
Try 1080
2002 Boxster becker 1 radio that needs a code due to dead battery Model #4362 serial #25007222
I would really appreciate your help!
Try 0950
Can you please help me? I replaced my battery and now the radio doesn't work.
Becker 1
Type 4462
Serial 15063573
Worked like a charm. Thank you! :)
I will write it down in my owner's manual, where I originally looked.
You really saved my radio from the trash because dealer wanted $75 for the code.
Then perhaps a small donation to help keep this site running..... Thank you.
Yup replaced the battery in the wife's 2000 Boxster and guess what? Need the radio code. We've only had the car on the road a month. No manuals, stickers or anything. Any help would be appreciated.
4462 model
X5031065 is the serial.
I wonder if you could please help me.
I has the battery replaced and can't find the radio code.
From the forum post I believe this is the information needed.
CDR-22
Type 4467
SER: X5015878
Thank you in advance for your help,
Pedro
Need a radio code after changing my battery. CDR-220 Type 4362 and Serial Number 25007456.
Thanks in advance for your help.
Mike
4462 model
Try 0430
CDR-22
Type 4467
SER: X5015878
Pedro
Try 3236
Mike
Try 7159
CDR-22
Type 4467
SER: X5015878
Pedro
Try 3236
It worked.
Thank you.
Will donate.
Mike
Try 7159
Worked like a charm. Thank you so much! :)
Loren,
I know you have helped me with this in the past.
Just picked up a 2000 Boxster S and I am in need of the radio code.
CDR 220
Serial #: Y5036438
As always,
Thank you
Loren,
CDR 220
Serial #: Y5036438
As always,
Thank you
Try 7205
Was working fine of course till the battery removal. Previous owner did not write it in the manual... Following your radio I.D. recovery procedure I've gotten the following: CDR 220  Type 4362  and serial # 15004832. Hope you can help. Thank you in advance. The radio code is the most important item for me at this time.
