  • Replies 19.2k
  • Created
  • Last Reply
Top Posters In This Topic
17 hours ago, Lovellmark said:
Can you help me with my radio code?
i have a2001 Boxster s
my radio type is BE4462 and the serial number is15086075
thanks!
Try 6565
4 hours ago, otten8208 said:
Loren,
Please help me to find the radio code for a CDR-210 for a 1998 Boxster?
Model# R3297
S/N W5021955
Mike
I have removed your duplicate posts - really no need to post 5 times.
Try 4861
Hi Loren
Can you please lend a hand?  Had some work done to my car and don't have the code.
CDR-220
BE4462
15062518
3/01
Adam
1 hour ago, Adam_ said:
Hi Loren
CDR-220
BE4462
15062518
3/01
Adam
You should always use the procedure in the Lost Radio Code FAQ as the stickers can be wrong if the radio has ever been repaired. So the most reliable way to get your radio serial number is to use the procedure so that it is displayed on the radio.
If your radio has not been repaired then this should work - try 9854
27 minutes ago, shooterstar said:
Hey there and nice Greets from Vienna - thanks in advance for help
Radio:
CDR 22
Model-No.: BE 4467
Serial: Y5023571
EC: 112
Thanks.
Try 9098
Hi Porsche lovers ,ok yeah got my Porsche delivered from another country ...battery gone empty ,now need the code..
here is what I have thanks to this forum :
I also need a radio code for a cr 210 Porsche 996 / 1998
I have these nrs:
R 3297
Serial : W 5011167
All help is very welcome.
I have these nrs:
R 3297
Serial : W 5011167
Try 8314
I have a 2001 996 with the CDR-220 radio.  The serial # is Y5054534, and the Type is 4462.
Any help with the code would be appreciated.
Thanks in advance!
4 minutes ago, Piacenza said:
Thanks in advance!
Try 6532
35 minutes ago, ElysiumSA said:
Need a code for my mother's Boxster S.
CDR-220
Serial: 15061780
(Other numbers that came up)
24/99
CD: CDP2081
Type: 4462
Try 2708
So, I am getting desperate. I read the FAQ re: radio codes and it didn't say anything about the CD-2 radio that came with the 1991 964 C2 Cab I recently purchased.
Just in case the code can be retrieved the badly worn #'s on the back are: S/N0 PO CD-2 A 06 14728 and below that # is B 0 06 14728B
I have called a few dealers with no luck!
What else can I do?
Thank you in advance
Magilla
What else can I do?
Magilla
Sorry, we can only help with the radios models listed in the FAQ.
