4 minutes ago, Loren said:
Try 8594
Wow, that was THE FASTEST response EVER. I'll try it since my Porsche store didn't know the first thing about it (which I find kinda strange....).
  • Replies 19.2k
  • Created
  • Last Reply
Top Posters In This Topic
1 hour ago, Loren said:
Try 8594
Worked, finally. Quite irritating to have to drive without a radio (even though it's an old FM radio). Thank you soooooo much.
Edited by Stein Grongstad
Text was separated.
Hello Loren,
After four years of ownership I finally had the battery die enough to kill the radio!
VItals are:
CDR2065
Model: 4462
Ser: X5016556
Thank you so much!
Steve
Found the old one that you gave me (5318). Going to give that a try.  Thanks!
Edited by Drsrharper
31 minutes ago, Harvey Powers said:
Hi Loren,
I'm trying to get the following radio back to life:
CR-220
Ser: 15050293
Try 7681
6 minutes ago, JohnMinickene said:
I lost the code for my radio. of 4462 and a serial number of xs027072
Can I get the code?
Try 5351
Hello guys i posted earlier but im not sure if i posted in the right spot. So I have a 2000 Porsche 911 and battery died and now radio is locked.
Becker 1
type: CDR 220
model: BE 4462
serial number: Y5051133
thank you guys in advance
Becker 1
type: CDR 220
model: BE 4462
Try 5458
Loren thank you very much... code 5458 worked on the very first try. Im back to dancing while im driving lol
Loren,
I just bought a "used 2001 Boxster S without a noted radio code under the hood and no supporting documentation! If you could be so kind to supply me with a code it would be greatly appreciated.
CDP2081
Type 4462
SER Y5045189
thanks again
Steve
5 minutes ago, slg15aa said:
Loren,
CDP2081
Type 4462
SER Y5045189
thanks again
Steve
Try 4650
1 hour ago, hotweast said:
I have a 2002 Boxster S and require my radio code. My serial number is 25005450. Thank you very much. adam
What radio model please? (on the front of the radio)
Sorry Loren, my oversight. CR-220. Thank you.
Try 1076
On 5/6/2017 at 10:01 PM, Loren said:
What happened to the different radio (and code) I gave you in March 2017?
I finally got around to fixing the fuel sending unit and when I tried the code you sent it would not work. I looked up the serial # I sent you and noticed i forgot the last number. My apologies for not stating that info in the 2nd request.
Thx
Bill
34 minutes ago, Superbaby said:
Hello - 2000 Boxster S battery replacement and in need of radio code. CDR220 Serial # Y50354965.  Thanks!
Try  1291
45 minutes ago, nosub said:
1998 Porsche Boxter. CDR 210. Model BE 2282. Serial number V5015620. Code please and thank you.
Try 9604
