  • Replies 19k
  • Created
  • Last Reply
Top Posters In This Topic
Hi There
I have just disconnected my battery and guess what I haven't got the radio code, the radio is a CDR32
Model Number: BE 6622
Serial number: 15000666
Porsche part: 996.645.123.10
Any help appreciated
Thank you
Bruce
55 minutes ago, bruce_english said:
Hi There
Thank you
Bruce
Hmm, looks like you did not read the Lost Radio Code FAQ .
"CDR-23 (or later):
These radios are security tested on the MOST (fiber optic bus) system to see if they are the "programmed" radio. The radios are programmed and recognized by the car’s DMEand can only be replaced by a shop with a PST2 or PIWIS. These radios will not request a code when battery power is disconnected."
"CDR-23 (or later):
Hi There,
I did read the FAQ, which is why I was surprised when after disconnecting and then reconnecting the battery I got this on the radio display, are you saying I now need to take it to a Porsche dealer to have the radio coded?
7 minutes ago, bruce_english said:
Hi There,
You can try 8401
but if that does not work then the OPC - sorry.
1 hour ago, Jeffrey LaDue said:
Good Evening, requesting assistance with radio code for the following:
2001 Boxster
CR-220
Type: 4362
SN   Y5024026
Thanking you in advance!!
Try 5049
5 hours ago, Jolita Akelaitiene said:
Hello, maybe could help with this one radio code?
CDR 210
Model BE 2262
Serial S5000004
thanks!
IMG_2812.thumb.JPG.0291ad08357397ff62f09a307a0222b0.JPGHello,
Try 1032
34 minutes ago, Jrfishel1 said:
Good evening and thank you in advance
CDR-220
Type 4462
Serial- xs024430
This is the 5th radio you have asked for -- perhaps it is time for you to donate to this site?
