9 minutes ago, Loren said:
Try 9876
No gofundme page as costs of running this site are ongoing - you are welcome to donate (especially if you can do it annually).
I will try that as soon as I get home Loren and donate I will!  All the best.
  • Replies 19k
  • Created
  • Last Reply
Top Posters In This Topic
Hello,
I had to finally replace the battery on a used 2002 boxster I purchased. Had all the manuals except the battery card. I appreciate any elp you can provide. The information I retrieved is as follows:
CDR-220
Becker 1
Type 4462
Serial 15001263
Thanks in advance.
24 minutes ago, DLewis33 said:
Hello,
CDR-220
Becker 1
Type 4462
Serial 15001263
Thanks in advance.
Try 2767
Thank you Loren, the code worked fine. Also, I saw that you must use Paypal to donate. Is that the only way? No credit cards or checks?
PayPal also is our credit card processor - just choose to not open a PayPal account. Thanks!
On 1/8/2018 at 8:56 AM, Loren said:
Try 9876
Worked right away!  Donation happily made.   It is worth noting I just changed immobilizer and ECU/DME (with matching key fob) myself (i.e. not at a shop) so the radio either updates the ECU itself automatically or the code to make the radio work is stored in the radio and not the ECU.  Hope that info helps someone someday.   Best
For MY 2002 and older the radio code can be stored in the DME - but it is not used. The radio code for those years is only used in the radio itself.
In MY2003 (and newer) the code validated up by the radio by the DME.
Replaced the battery in my 2000 Porsche Boxster S and now need a code to enable the radio.
CDR-220
Type: 4462
Serial # : Y5035583
Are you able to help with the code?
Thank you
Edited by ejessen
CDR-220
Type: 4462
Serial # : Y5035583
Thank you
Try 9308
  • Thanks 1
Had to jump my 2002 Boxster and the radio went to safe mode.. Help is greatly appreciated!
Becker 1
Type 4462
Serial 15003563
It looks like my screen may have some pixels missing so I'm not completely sure about the las 6 on the serial.. Looks like a 6 but might be something else.
Thanks in advance
Becker 1
Type 4462
Serial 15003563
Thanks in advance
Try 9024
Hi Guys,
new to this site and the Porsche life
just got a Porsche Boxster 2002 with the radio requiring a 4 digit code
serial number is 15005907
type 4462
Can anyone please assist as it would be appreciated
thanks
3 hours ago, Ozgolding said:
Hi Guys,
type 4462
thanks
1
Try 7052
I got a Porsche Boxster 2002 recently and disconnected the radio to try to test an after market radio, and need help with the radio code.
Type : CDR 220
Model No : BE 4462
Serial No : Y5047237
Any help would be appreciated
43 minutes ago, Jacob said:
Type : CDR 220
Model No : BE 4462
4
Try 4654
I have a 2000 Porsche Boxster and do not have the radio code.  Becker1 Model 4462  Serial Number Y5040398.   Can you help me with a code to unlock the radio?  Thank you for any assistance
Edited by Brian Ronald
More accurate information to post.
23 hours ago, Loren said:
Try 9024
Thanks for the help but unfortunately it did not work.. Maybe as I said, the serial is wrong.. Here is a pic let me know if you can figure it out.. Or is there any other way to get the serial? Thanks a lot
