32 minutes ago, Loren said:
Ah, that is the proper serial number.
Try 1305
Try 1305
Dear Loren, Thank you, the code worked and radio up and running. Best regards
  • Replies 19k
  • Created
  • Last Reply
Top Posters In This Topic
On 2/23/2018 at 12:17 PM, Loren said:
Try 2726
When I was discussing this issue with the local Porsche dealer service manager, he looked up the model and SN and suggested 2796.  Which ever one works, how do you test this without disconnecting the battery?  Is there a menu choice on the radio where you are prompted for the code, when it is fully operational already?
Read the Lost Radio Code FAQ
1 hour ago, Ernie0304 said:
Sorry Loren, I think I posted my request in the wrong place.
My data:
Type 4362
# 150508 18
24/99
Thanks, Ernie
Try 6786
Hi - I could also use help.  Just had my alternator replaced and now need my radio code.  Got my 2001 Boxter a couple months ago but no books or radio card with the car.
Serial # Y5024058
Type 4362
24/99
Also, when turning on the radio after the PORSCHE goes away it says 'wait' - At least that's what it did yesterday after the car was started a couple times.  I don't see where I would enter a code?  Does that mean my mechanic tried to enter a code and it locked up? (EDIT: - Just read you have to wait 30 mins)
And advise would be much appreciated!
Thanks, Rob
Edited by Lebby83
Adding text
Serial # Y5024058
Type 4362
24/99
Thanks, Rob
You need to read the Lost Radio Code FAQ
Try 8989
Try 8989
Thank you!.  Will try it tonight.  And yes, I read the FAQ after I posted and saw the comment about waiting 30 mins.
Hi Loren.  I need help as well.  Just purchased this '02 Boxster and I don't have the code.
CDR-220
Type 4162
S# 25014149
24/99
Any help will be most appreciated.
Edited by PacoGrande
typo
CDR-220
Type 4162
S# 25014149
24/99
Try 0936
Hello Loren!
Just swapped the engine and transmission and resurrected this girl! But alas, no tunes without a code. Can you see if you're able to find this one?
Becker CDR 220
Model: BE4462
Serial: y5051133
Date 41/00
Thanks in advance for any help!
20 minutes ago, mrvict0r said:
Hello Loren!
Becker CDR 220
Model: BE4462
Serial: y5051133
Date 41/00
Try 5458
I have a Becker 220 radio in my 1999 Porsche 911 996 and cant find the code
type 4362
serial number x5013097
thanks in advance Loren
Edited by ssindyrider
type 4362
Try 0206
Just purchased a 2002 Porsche Boxster. Battery went dead. Here are the specs
Becker 1
Type 4462
Serial # 25013601
this came up  24/99
Yes I did I this isi the information I got on the display
Becker 1
Type 4462
Serial # 25013601
this came up  24/99
Becker 1
Type 4462
Serial # 25013601
this came up  24/99
1
I never am\nswered your original post - you read someone else's.
Try 0143
