Loren,
It worked perfectly.  You are my hero!!!   I think it's awesome that you are helping so many people.  Much appreciated and thank you again!!!!!
  • Replies 19.2k
  • Created
  • Last Reply
Top Posters In This Topic
4 minutes ago, rwoodroffe said:
I couldn't get it to work. Do I need to do anything special after entering the code?
Richard
No.
If the code does not work then chances are your radio was repaired by someone other than Becker and the is lost. Sorry.
Hello seeking code for my 996 please
Y5052895
CDR-220
many thanks!
Edited by Ronan
1 hour ago, Johnniejohnsonv said:
no luck ? must have been repaired at some point.. thank you Loren i now know which steps to take next, calling the dealership in the morning.
Sorry, try 0469
5 hours ago, zady mendoza said:
Hi. I need help with my radio code. It’s a Boxster S 1998. Radio is cdr210 and the serial number is V5008201.
Try 1096
Loren, after a good hot fire , a replacement front harness, paint, undercoating, a donor car for all the plastic that melted. Followed With a pts2 recode to abs pump replacement, now down to Litronics and radio!
Cdr220
typ 4462
serial # 25016872
thanks!
8 hours ago, Travis Worthington said:
had to take my battery out, need help with radio code.
It is a becker CD-220, serial number is W5007213.
Thank you!
Try 0878
