1 hour ago, Charles Daugharthy said:
Car is new to me and the owner said she never had the code!
Becker 1
4462
W5011561
CDR-220
Appreciate any help!
Try 0203
  • Replies 19.2k
  • Created
  • Last Reply
Top Posters In This Topic
Hello, I recently purchased a 2000 Boxster S with a CDR-220 with serial Y5042326 (I believe the second character is a 5, it may be an S), type 4462. Any help would be greatly appreciated. Thank you!!
Try 6565
1 hour ago, 98 Boxster Guy said:
Hi Loren,
No one has repaired the radio, can you recheck this?
If the code I gave you does not work then either you gave me the wrong serial number or the radio HAS been repaired by someone other than Becker.
In that case I can not help you, sorry.
Could you help me out please with the radio unlock code for my Boxster Becker CDR 220.
From the label ...
Typ: CDR 220
Model No.: BE 6625
Serial No.: 15010066
Many thanks in advance,
Tony.
1 hour ago, tony1965 said:
From the label ...
Typ: CDR 220
Model No.: BE 6625
Tony.
Sorry,  I missed your first post.
Try 4212
Hi - looking to get the radio code for my 1999 986 after I disconnected the battery to work on the airbag retaining frame.
It's a CDR-220 with serial number X5023571.
Thank you in advance for the help!
Try 9098
Hey just bought a 99 Boxter with no code any help will be great full, thanks.
CDR-220
BE: 4462
Serial: X5021171
Edited by JustinAllen325
Needed more.
CDR-220
BE: 4462
Serial: X5021171
Try 8346
Hello,
I just purchase a 2000 911 Carrera Cab but i need the code for its radio. Any help would be appreciated. Thanks!
Its a CR -220
Becker 1
serial Y5023008
type 4362
24/99
1 hour ago, Rxvino said:
Hello,
Its a CR -220
Becker 1
serial Y5023008
type 4362
24/99
Try 8679
Just bought my first Porsche. '02 911 (996) and I don't have the radio code. please help.
Becker CDR-220
Model: BE 6625
Serial#:  15006252
Thanks in advance!!
Sean
Becker CDR-220
Model: BE 6625
Serial#:  15006252
Thanks in advance!!
Sean
Try 4964
Negative battery cable came loose and reset my radio and need the code.
1999 C2
Cr-210
Ser# V5009445
Thank in advance!
1999 C2
Cr-210
Ser# V5009445
Thank in advance!
Try 3621
Loose power cable reset the radio. No owners manual when i bought the vehicle. Any help would be greatly appreciated!
Radio CDR220
Type 4462
SER X5017715
Thank you!
