  • Replies 19k
  • Created
  • Last Reply
Top Posters In This Topic
Hi Loren,
Hope you can help a newbie out from the other side of the pond......
Just bought my first 986 yesterday and it needs a radio code
Type: CDR-22
Model: BE 4462
Serial: X5012417
Thanks in advance Antony
25 minutes ago, MadAnt said:
Hi Loren,
Type: CDR-22
Model: BE 4462
Serial: X5012417
Try 0878
  • Thanks 1
47 minutes ago, Loren said:
Try 0878
Excellent Loren thanks for the quick response.
I now have a working radio & CD player...😊
Hi everyone, new to the forum. I just changed the battery in my 1999 996 Carrera 4 and now I need a PCM code that I don't have. Not sure what radio it has but it is am/fm/navagation with 6 disk changer in the bonnet. Any help will be greatly appreciated.
Didn't take the time to read the Lost Radio Code FAQ...
"Can you give me a code for my PCM?
These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/ OPC. The PCM’s require two codes, the ICS/Siemens code, and a Becker code. The ICS is the first code requested.
Sorry, the only place you can get a PCM code is from a dealer/ OPC."
Hello,
I have the same problem, I wasn't aware of the unlock codes for the radio when I changed the battery.
Boxter 1999
Becker CDR 220
type CDP 2081
serial # Y5045543
CARRO WPOCA2989XU631931
Thanks for your help 🙂
16 minutes ago, FEDERICO OQUENDO said:
Hello,
Boxter 1999
Becker CDR 220
type CDP 2081
serial # Y5045543
Try 5404
  • Like 1
I could use help with a code for my 1999 Porsche Boxster:
Cr 220
When I press the tp button these are what I get:
Ser: X5013077
47/98
Type 4362
Gal:00
Aux OFF with up and down arrows underneath.
Thanks so so much!
Cr 220
Ser: X5013077
47/98
Type 4362
Gal:00
Thanks so so much!
Try 1046
On 9/26/2019 at 4:32 PM, Loren said:
Try 1046
I need more help I guess.  I've tried entering the 1046 at several points and nothing works.
The stations buttons are not numbered so I'm assuming that it's 1-9 and then 0.  Or does 0 come before 1?
At which point do I do the 1046?  What should be showing on the display when I press the station buttons?
Thank you so much, I really appreciate your help!
Lost Radio Code FAQ
Replaced battery in 1997 Boxster and need unlock code please.
CR-210
Type: R 2095
Serial: V5004615
Edited by jdhutton42
adding more info
