  • Replies 18.9k
  • Created
  • Last Reply
Top Posters In This Topic
Hi Loren,
New to Porsche and had to disconnect my battery due to a failed ignition switch.  Ordered parts and repaired.  Reconnected the battery and surprise!
1999 C2
CR-210
S# W5010472
Thank you!
1 hour ago, DMAXISON said:
Hi Loren,
1999 C2
CR-210
S# W5010472
Thank you!
Try 9876
2 hours ago, juliannp said:
Just got a new Boxter and the radio requires a code! Hoping you could help me out.
2000 Porsche Boxter S
CR-220
S W5002820
Try 6432
2 hours ago, Reeces Pieces said:
Hello,
I have a 1998 Boxster. As far as I know all the info below is correct.
CR-210/CDR-210
T5003855
Thank you very much!
Try 6512
2 hours ago, Brian Bentley said:
Hello, I got this car with a dead battery, now the radio needs a code, I pulled it and got the serial # it’s
BE4462
W5009492
thank you for the help.
Brian.
Try 7571
