Hey Loren,
That worked! I really appreciate all of your help and your patients!
Thanks again my friend!
Edited by JCFX
  • Replies 19k
  • Created
  • Last Reply
Top Posters In This Topic
On 6/28/2023 at 2:15 AM, JB Racing said:
I need help with a CDR 220 radio code can anyone please assist
Model no BE 4662
Serial no X5032574
Thanks in advance
Try 0217
1 hour ago, gavinomachino15 said:
I know this thread is old but i need the code for a CDR-220.
Serial number: x5037858
model:4462
Try 9121
On 5/16/2023 at 10:22 PM, Loren said:
Lost Radio Code FAQ
Hi
I have recently acquired a Boxster that has the PCM BE-2580. I know it says doesn't cover the PCM due to siemens doing the navi code, however I do have the navi code card and the code that came with the car. I literally require the PCM code only as was missing. Is this something that can be helped with please? If so what more is needed from me? Thanks in advance
5 hours ago, alanpettit said:
Hi
These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/OPC. The PCM’s require two codes, the ICS/Siemens code, and a Becker code. The ICS is the first code requested.
Sorry, the only place you can get a PCM codes is from a dealer/OPC.
  • Like 1
10 hours ago, Nabeelo said:
Hello, can you kindly provide a code for a CDR-220 Model#: 4462 Serial#: X5023563
Thank you in advance.
N-
Try 9024
I’ve been without radio for some time, hoping it is still possible to unlock. Thank you in advance!
Serial number pictured Y5047003 or YS047003
Try 1215
Siemens
5WK 78003 - - E
PO8030205471/04
996.642.904.04 EFR
SI000406010209
Becker
IDIS
BE 2580
55150096
Please I need 2 code for Porsche 996
2 hours ago, Tom ptr said:
Siemens
5WK 78003 - - E
PO8030205471/04
996.642.904.04 EFR
SI000406010209
Becker
IDIS
BE 2580
55150096
From the Lost Radio Code FAQ...
"These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/OPC. The PCM’s require two codes, the ICS/Siemens code, and a Becker code. The ICS is the first code requested.
Sorry, the only place you can get a PCM codes is from a dealer/OPC."
34 minutes ago, Tom ptr said:
Thank 😉
Have you got a web site or contact for the first code ?
No, the only place you can get a PCM codes is from a dealer/OPC.
Hello, in need of the radio code for my Boxster, seems the card that came with the car is no longer with the owners manual.
Becker CRD-220
Ser: Y5041728
Type: 4462
Thanks so much!
Becker CRD-220
Ser: Y5041728
Type: 4462
Thanks so much!
Try 3292
Hello, We are hoping to get the radio code for this 2000 Boxster.
CR-220
Model: 4462
Serial: X5038003
Thank you!
CR-220
Model: 4462
Serial: X5038003
Thank you!
Try 1025
40 minutes ago, Jeeplife said:
Add me to the list of those needing helop with this! Thank you so much in advance!
Serial # W5018757
Model# BE2282
Try 1549
