Need some help getting a radio code. My family has a 2001 Boxter S and we disconnect the battery every winter for storage and the radio has been asking for a code for a while now.
Becker CDR-220
Model No. BE 4462
Serial No. 15086165
  • Replies 19k
  • Created
  • Last Reply
Top Posters In This Topic
Becker CDR-220
Model No. BE 4462
Serial No. 15086165
Try 0684
6 hours ago, Allen Chipley said:
Bought replacement radio for my 2003 Porsche Boxster on Ebay and need the radio code. Model #BE6612, serial #35051265. Thank you!
From the Lost Radio Code FAQ...
"CDR-23 (or later):
These radios are security tested on the MOST (fiber optic bus) system to see if they are the "programmed" radio. The radios are programmed and recognized by the car’s DME and can only be replaced by a shop with a PST2 or PIWIS. These radios will not request a code when battery power is disconnected."
55 minutes ago, CabrioArtie said:
Loren,
New radio for my car, but need the code.
Model - CDR-220, BE4462
Serial - 15075092
Thank you,
Artie
Try 9475
Just got my 996 ME, previous owner lost the radio code
Becker CDR-220
Model No. BE 4462
Serial No. X5032312
Thanks.
31 minutes ago, Alan Boo said:
Becker CDR-220
Model No. BE 4462
Serial No. X5032312
Thanks.
Try 6453
  • Thanks 1
Hey there, just woke up my 2002 996 after a long hibernation. I have no code on hand (have never needed it before).
Becker CDR-220
Model No. BE 4482 (I think, as some of the pixels are out)
Serial No. 15007779
Thank you so much!
Becker CDR-220
Serial No. 15007779
Thank you so much!
Try 4895
  • Like 1
That one didn't work, thank you for getting back. Happy to try any other options you suggest.
Edited by slav
In a similar position looking for CDR 220 code so I can re-install the orig deck back into my 02 Boxster S
Model: BE6625
SN: 15001966
Model: BE6625
SN: 15001966
Try 4949
13 hours ago, Branden Dunn said:
Trying to get radio code for my 2002 boxster.
Model No.BE6624.
Serial No.15005181
Thanks in advance
Try 2102
