  • Replies 19k
  • Created
  • Last Reply
Top Posters In This Topic
Hi
I have the  problem, I wasn't aware of the unlock codes for the radio when I changed the battery.
Becker CD-22
type BE 4367
serial #  W5005738
Thanks for your help 🙂
4 hours ago, Attila hun said:
Hi
Becker CD-22
type BE 4367
serial #  W5005738
Try 4947
I recently acquired a 1999 996 and unfortunately did not receive the radio code or the PCM code. The car was optioned with navigation and a 6 disc CD player which were both removed. As seen in the attached photo, there are two labels on the navigation unit, one Becker (X5008025) and one Siemens (P08010010279/02), with different serial numbers. Does anyone know which one would be helpful in finding the radio code and if either one would help in recovering the PCM code?
From the Lost Radio Code FAQ....
"Can you give me a code for my PCM?
These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/OPC. The PCM’s require two codes, the ICS/Siemens code, and a Becker code. The ICS is the first code requested.
Sorry, the only place you can get a PCM code is from a dealer/OPC."
Need radio code for
1999 Porsche Boxster
Type 4462
CD.  CDP2081
48/98
Ser.  X5025620
Please help me with the radio code
Will
Edited by Will Corder
1 hour ago, Will Corder said:
Need radio code for
Type 4462
CD.  CDP2081
48/98
Ser.  X5025620
Will
Try 9604
Same problem here! Previous owner replaced the battery and didn't have a code.
Becker CDR 210
Type BE 2232
Serial # U5011529
Edited by CJChaps
1 hour ago, CJChaps said:
Some problem here! Previous owner replaced the battery and didn't have a code.
Becker CDR 210
Type BE 2232
Serial # U5011529
Try 9132
Hello -
I have a 2001 996tt with Becker CDR-220.
Had work don over the last few weeks and lost the radio set-up.
Serial number:  15089443
Any help recovering the code would be appreciated.
Thank you
1 hour ago, jimo55 said:
Hello -
Thank you
Try 3595
I have just bought a 2000 Boxster from my sister. We did repairs with battery disconnected. Now can't find radio code to operate radio. Have read LOST RADIO CODE First doc and retrieved serial #. Any help would be so appreciated, thank you.
Radio: CDR-220
Serial: Y5042538
Radio: CDR-220
Serial: Y5042538
Try 9014
Hi guys,
looking for the code for a 2001 996 base Carrera.
these are the details:
CDR-220
ser: 15087199
24/99
type 4462
thank you for your help!
ed
9 hours ago, Brendan Dolan said:
Hello! New guy here. Got a 986 for my Dad, and after a battery replacement the radio code isn't working. CDR 220 model 4462, serial number x5028266. Appreciate the help!
Try 5210
2 hours ago, Edcantera said:
Hi guys,
CDR-220
ser: 15087199
24/99
type 4462
ed
Try 0876
  • Thanks 1
Hi, I can’t find my radio code. Can you help?
CDR-220
Type 4462
Serial Number W5006434
Thanks so much.
Adam
CDR-220
Type 4462
Thanks so much.
Adam
@Loren thanks so much in advance for your help
