  • Replies 19k
  • Created
  • Last Reply
Top Posters In This Topic
12 hours ago, emflo88 said:
I just bought a 2002 Targa with a CDR-220 radio that isn’t working.
i cannot find any radio code in the paperwork.
what I do know is:
type: CDR 220
Model: BE 6625
Serial: 25011054
date of manufacture: 03/02
i also have a 6 CD changer connected but cannot see a model number on it without removing it.
how can I get the original radio code so I can at least test if this radio will work or not ?
thanks
Try 0242
55 minutes ago, Jamie OKeefe said:
Hello
I have a Richmond Blaupunkt and need a code.
Serial Number 61057306
Warranty B513003459
Sorry, I have no idea.
Please read the Lost Radio Code FAQ
"Which radios fitted to Porsche can have their unlock code recovered through serial number?
- CR-220/CDR-220 - Becker
- CR-210/CDR-210 - Becker
- Traffic Pro NAV/CD - Becker"
29 minutes ago, Gabriel Gillard said:
I really need the 4 digit code to unlock my Porsche radio CDR 220
Serial number: Y506-1181
Try 8426
  • Like 1
7 hours ago, Davelo said:
I have the same problem lost the radio code for Boxster 2000 with serial numbers Y5043589 can you help me please!
Try 1047
I will need a stereo code for a 2000 996
CDR-220
Becker 1
Model 4462
S/N: Y5041491
24/99
Julio
Edited by Julio Rico
1 hour ago, Julio Rico said:
CDR-220
Becker 1
Model 4462
S/N: Y5041491
24/99
Julio
Try 9828
  • Like 1
Loren, any chance you could find code for a PCM NAV unit?
Type: PCM
Model: BE 2562
Serial: X5008531
Siemens below
MLFB: 5WK 7801
Serial: PO8010015380/02
Type: PCM
Model: BE 2562
Serial: X5008531
Siemens below
MLFB: 5WK 7801
You did not read the Lost Radio Code FAQ...
"Can you give me a code for my PCM?
These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/OPC. The PCM’s require two codes, the ICS/Siemens code, and a Becker code. The ICS is the first code requested.
Sorry, the only place you can get a PCM code is from a dealer/OPC."
3 hours ago, SF1098 said:
Apologies, I got here from duck duck go.
Sorry for the additional question. What is OPC?
OPC = Official Porsche Center (same as Porsche dealer)
Hello,
Looking for code for Porsche 2000 - looking everywhere
thank you in advance!
CDR-220
Becker 1
Model 4462
S/N: Y5038178
24/99
10 hours ago, J.B said:
Hello,
CDR-220
Becker 1
Model 4462
S/N: Y5038178
24/99
Try 9593
I need a code for radio reset after replacing the battery
have a 2000 Boxster S with a
Becker CDR 220 with CD player 4462
Serial no 15064818
Appreciate your reply
Cptn Bob
