Hello, I just purchase my 97 Boxster and can not find the radio code. If you could help it would be much appreciated!
CDR-210
Model: R 2896
Vin: V 5005540
Thanks in advance!
  • Replies 19.1k
  • Created
  • Last Reply
Top Posters In This Topic
CDR-210
Model: R 2896
Vin: V 5005540
Thanks in advance!
Try 5380
  • Thanks 1
My 2001 Boxster S needs a radio code. radio is the 4462 type and the SERIAL # is:  W5012191.
Could you provide the code?  Thanks for this great service.
Carl
52 minutes ago, carlfrank said:
Carl
Try 8316
  • Like 1
3 hours ago, old school shifter said:
need radio code for 02 boxster S Becker Radio model 4362; serial # 25005455
please
Try 1216
  • Like 1
Hello,
Just bought this 986 Boxster, I found a radio card with the serial, but no code.
Model: CDR-210
Serial: T1007413
Card also has CDC-3 written before the serial, not sure what that's for just in case!
Thank you!
5 hours ago, hsingh7 said:
Hello,
Model: CDR-210
Serial: T1007413
Thank you!
CDC-3 is the 6 disc cd-changer in the front trunk.
Try 3231
3 hours ago, Chuck Wheeler said:
Help lost code cdr-210
sn v5006235 new to this car and previous owner did not have code thanks
Try 4828
Thanks Loren the code works but I got some other problems lol no sound have more to check out this weekend but at least the radio is on and appears to work correctly except the volume button doesn’t seem to do anything lol fun with Porsche
Old Porsche guy - new member.
Just got a new to me 1998 993 Cab and the radio is showing CODE due to
a battery replacement by the prior owner.
I have read this entire thread (and a few on other Forums) and found some instructions on retrieving the radio
code for the CDR 210 radio but no videos or pictures or  button location and definitions
such as TONE and TP.
Do I need a magnifying glass for these old eyes?
Are special tools required to slip the radio out of the dash and look for the number?
Anyone got a PDF file for this radio or a drivers manual ?
Doesn't seem to be much posted on uTube.
thanks in advance..
Please ignore prior questions about CDR 210 button definitions.
I was able to finally locate a download PDF (attached).
Hope this helps someone in the future.
I haven't tried the code reset procedure yet - pages 9 thru 11.
Edited by Loren
Removed copyrighted material
