Hello Loren,
I recently requested to code to my original Becker radio and it worked, but unfortunately spilled soda all over the radio due a sudden braking incident. I purchase a used CR-220 Serial W5007293. Can you please help with the radio code?
Thanks again.
  • Replies 18.9k
  • Created
  • Last Reply
Top Posters In This Topic
3 hours ago, quietcoolone said:
Hello Loren,
Thanks again.
Try 5102
36 minutes ago, quietcoolone said:
Thank you. Unfortunately that one did no work. Is there any other code to try?
If you gave me the correct serial number  - then no. Sorry.
That is the serial as displayed on radio unless the second digit is an "S" and not a "5"
WS007293. Could that be the case? Please check and advise.
Thanks in advance for the help.
Only the last four really matter.
4 hours ago, bohnsolo said:
Hi Loren
Had to swap batteries on my Boxster and can't find the radio code.
CDR-220
X5020181
Try 8616
On 4/4/2008 at 8:37 AM, awacuex said:
thank you very much Loren the code 4907 work like a charm thanks again
Hi Loren, you have been a savior to so many on this forum for so long, rescuing us from the sound of silence. I hope you are doing well and still providing this invaluable service.
I got locked out after changing a dead battery on my 2001 Porsche 911 Carrera 4. Can you please provide a radio code? Thank you kindly for your help,
Becker 1
Type 4462
S/N - 15062490
Hi Loren, We bought a 1999 Boxster and of course the radio does not work. We're at a disadvantage because we do not have the radio code or  serial number of the radio. I've attached pictures of what we have and would be forever grateful if you would be able to help us with the radio code.
Thank you
Becker 1
Type 4462
S/N - 15062490
Try 5046
Thank you
Please read and follow the instructions for your radio in the Lost Radio Codes FAQ - then repost in this thread.
21 hours ago, Loren said:
Try 4359
It worked. Thank you so much. If I donate does it go to you? if not how do I send you money. You definitely deserve to be paid for providing the correct code.
All donations go to the costs of running this site. Thank you.
Good day Loren,
Looking for a security code to resurrect my original CR-210.
Becker CR-210
S/N - V5007367
Thank you in advance!
Alex
2 hours ago, c2ss said:
Good day Loren,
Becker CR-210
S/N - V5007367
Alex
Try 2863
15 minutes ago, kevin villani said:
I have a 911 with Becker CDR 220 model 4362, serial Number X5013147 Hoiw do I get the code?
Try 4190
