  • Replies 18.9k
  • Created
  • Last Reply
Top Posters In This Topic
2 hours ago, Ryan Marks said:
Still having trouble with my boxsters radio code I’ve tried 2743 and 0380
serial number y5042095
thanks
Okay 0380 should work if it does not then radio was likely repaired by someone other than Becker. If that is the case I can not help you... sorry.
Becker CDR-220
Model 4362
Serial X5015542
47/98
If I could only figure out where I put the owners manual!  Feel pretty dense right now.
Steve
8 hours ago, seh73 said:
1999 996
Becker CDR-220
Model 4362
Serial X5015542
47/98
Steve
Try 5396
Hello Loren,
I just purchased a 1999 911 and I cannot locate the radio code in the paperwork.
Model: BE 2282
Serial: V5017594
Thank you!
9 hours ago, Puddles said:
Hello Loren,
Model: BE 2282
Serial: V5017594
Thank you!
Try 5432
  • Like 1
1 hour ago, ColMacZA said:
Hi, Loren. Thank you in advance for your constant responses here.
Becker 1
X5036560
24/99
4462
Thank you again
Try 5350
Hi, Loren,
2000 Carrera here recently acquired with dead battery.
Radio Type CR 220 and Serial#
Y5022252
appreciate any help you can give, thank!
30 minutes ago, M Dickerson said:
Hi, Loren,
Y5022252
Try 2389
56 minutes ago, John Honey said:
Changed battery second owner need battery code
2000 Boxster S
Becker CDR-220
serial # Y5061032
Thanks So Much...
Try 1076
