1 hour ago, JC11 said:
Hi Loren,
My battery died and now I can't find my radio code. Please help!
2001 Boxster
CDR-220
Type 4462
Serial # Y5042817
If you need any more info, please let me know. Thanks in advance!
Joe
Try 6398
  • Replies 19.1k
  • Created
  • Last Reply
Top Posters In This Topic
12 hours ago, Cindy1972 said:
I need help too:
Make
Porsche
Model
Porsche CDR-220
Part Number
BE 4462
Serial Number
Y5048670
Please re-check your serial number as I am getting a "not valid" response.
2 hours ago, BrentInOly said:
I'd like to request a code if possible. Previous owner can't find it!
2002 Boxster S
CDR 220
SN from the display: 25015914
Thank you! Brent
Try 7108
I replaced my battery and can’t find my radio code. Help me please.
becker cr-220 ser x5017502 4362
thanks!
opps found it, its all good.
Edited by Blue pearl
Fix mistake
thanks!
:thumbup:
Hi Loren, Can you retrieve the code for my radio?
Becker Porsche CDR-22
Serial Number Y50267303
Thanks in advance. This car has actually been radio locked for years ever since I purchased it with the code lost, and I didnt know it was possible to recover it. Fingers crossed so I can hear the speakers for the first time.
Edit: I called a local dealer as well and provided the VIN (what they asked for) - they told me the code is 0464 but that didnt work. Followed up with them again and they said they dont know 🤷‍♂️
Really hoping all is not lost
Edited by Mveldsman
providing more info
Try 9876
7 hours ago, Mveldsman said:
Hm no luck with that one either. Any idea what is going on here? Thanks for your help
From the Lost Radio Code FAQ... "
The suggested number did not work - what do I do now?
Most often when the code we give you does not work it is because the serial number came from an old card in the car rather than from the procedure stated above - or a typo in the serial number submitted. Double check the serial number you submitted using the procedure above again.
If that does not work then you will need to contact a dealer or Becker. Becker charges to look up your code and some dealers also charge.
Our program works maybe 99.9% of the time but we have no explanation why it doesn't always work."
Ah Loren my apologies - I followed the instruction correctly but it looks like I fat fingered the serial number:
Correct serial number is Y5026303
Try 8956
Hey, many thanks for helping us !
Got these 2 radios without code, can you help me too please ?
Becker CDR-21 //  BE2280   V5012141
Becker CDR-21 //  BE2280   V5010651
Edited by tomatoto
Try 5432
Try 8281
Please consider a donation to this site.
Hi, may I please get the radio code for this radio which I received as part of a barter trade but without the code:
Typ: CDR22
Model No.: BE 6621
Serial No: 25006462
Thank you in advance
Typ: CDR22
Model No.: BE 6621
Serial No: 25006462
Try 7397
1 hour ago, maxbottomtime said:
Hi Loren! Hope you are well. I am hoping to get the code for my CDR-220. Serial is
Y5045046
Try 6523
Hi Loren, could I have some help with a radio code?
CDR-220
Serial no: Y5048979
Thank you very much!
CDR-220
Serial no: Y5048979
Try 7562
