  • Replies 19.1k
  • Created
  • Last Reply
Top Posters In This Topic
7 hours ago, Bob Manifold said:
Hi, I hope you can help provide radio security code
2001 Boxster
Becker CR-220
SN last 4: 9492
Thanks in anticipation
BobM
Try 7571
13 hours ago, Lincoln said:
Hi there have a CDR23
SN: 35046256
model Number: BE 6612
Could you help me find the code?
@Loren
From the Lost Radio Code FAQ...
"CDR-23 (or later):
These radios are security tested on the MOST (fiber optic bus) system to see if they are the "programmed" radio. The radios are programmed and recognized by the car’s DME and can only be replaced by a shop with a PST2 or PIWIS. These radios will not request a code when battery power is disconnected."
5 hours ago, Bob Manifold said:
I just realized it is a CDR 220. would that change the code?
BobM
No the code is by Becker serial number - and Becker made both.
