1 hour ago, Case Mitchell said:
Cdr-220. Can you help with a code for
y5042409 ?
This newbie thanks you!
The serial number determines the radio code. I must have the serial number to help you.
  • Replies 19.2k
  • Created
  • Last Reply
Top Posters In This Topic
Hi!  Here’s what it shows for the serial number.
4 hours ago, VidarHaaland said:
CDR-220
BE6625
Serial: 25015732
Could you please help me with the radio code?
Try 4909
I'd really appreciate help recovering the anti-theft code for my radio.
Car: 1999 Porsche 911 Carrera (996) Coupe
Radio: Porsche CDR-210 (Becker)
Type: R 3297
Serial number: W5022869
Both numbers were read directly off the radio using the TONE + 8/0 procedure (PR-VERS, then SERIAL N) — not from paperwork. Photos of the display attached.
Thank you very much for your help.
2 hours ago, Joe Khoury said:
Type: R 3297
Try 6814
54 minutes ago, Michael Bailey said:
I'd really appreciate some help retrieving the radio code for my car.
Car: 1999 Boxster
Radio: CDR 220
Serial number: X5025716
Thank you for your help!
Try 4871
I have a Porsche 996 from 1997 I think. Could someone please help with the radio code, I've already tried multiple tools online but none of them worked. The radio is a Becker BE4467 CDR-22 with serial number: X5018983.
Thanks in advance.
Gilles
4 hours ago, gillesdl said:
Thanks in advance.
Gilles
Try 7594
Hello Loren.
Was wondering if you could help with this one.
I have a Becker Monza.
Model:  BE 7886
Serial: 55002481
Thanks in advance!
37 minutes ago, C K said:
Hello Loren.
Model:  BE 7886
Serial: 55002481
Thanks in advance!
My program works on Porsche / Becker models. Becker Monza was not a Porsche model.
Loren, I need your help.  I have a 2002 Carrera 996, with a Becker CDR-220.  I was having some work done and battery was disconnected, here is the information for my radio.
Thank you so much for all your help.  I forgot to mention, i have a ride out coming up, and i could really use the radio.
Becker CDR-220
Type 4462
Serial X5036871
Edited by Omar Nesh
Becker CDR-220
Type 4462
Serial X5036871
Edited by Omar Nesh
Thank you so much, i'll try this code shortly and let you know how it turns out.  I really appreciate your help
