How to get your radio to display the serial number has been covered here many times. As well you can download the manual here.
Please do a search...
Learn something new everyday switch on hold down TP for 10 seconds. would'nt have found it without this forum many thanks.Could'nt find how to do it in the radio manual that came with the car.
Becker 1
type 4467
Serial no Y5026921
24/99
Try 6971
or
6973
My car stereo went silence as I changed battery a few weeks ago. Have been trying to get hold of the radio code through the used dealer I bought it from but no luck. I'd appreciate some help. here is the radio data:
Becker 1
Type: 4462
Serial: Y5040494
24/99
Thanks / Per
  • Replies 19k
  • Created
  • Last Reply
Top Posters In This Topic
Becker 1
Type: 4462
Serial: Y5040494
24/99
Thanks / Per
Try 9038
or
9040
Becker 1
type 4467
Serial no Y5026921
24/99
Try 6971
or
6973
Many thanks Loren
as an update to help others those 2 codes didnt work but 6974 did
Russ
Becker 1
Type: 4462
Serial: Y5040494
24/99
Thanks / Per
Try 9038
or
9040
Thanks. Tried it but it didn't work. :(
Becker 1
Type: 4462
Serial: Y5040494
24/99
Thanks / Per
Try 9038
or
9040
My program does not always work. It works maybe 95% of the time but I have no expanation why it doesn't always work.
At this point you will need to contact a dealer or Becker. Becker charges to lookup your code and some dealers do too.
Becker 1
Type: 4462
Serial: Y5040494
24/99
Thanks / Per
Try 9038
or
9040
No worries. I appreciate you trying. :)
Radio Code Please (I changed my battery)
Year: 2001 Boxster S
Engine: 3.2
Trans: M
Radio: CR220
Becker1
BE:4362
SN: 15050274
Thanks in advance!!!
Can you please give me the radio code.
2000 Boxster S
Its a Becker Type 4462
My Serial No. is X5027144
Thanks in advance
Why do you post AND send me a PM requesting your code?
Try 9507
or
9509
2000 Boxster S
Thanks in advance
Try 9507
or
9509
Neither 9507 or 9509 worked
2000 Boxster S
Thanks in advance
Try 9507
or
9509
My program does not always work. It works maybe 95% of the time but I have no explanation why it doesn't always work.
I have a 2001 Porsche 996 C4 Cabriolet with a Becker CDR220 (model # BE4462, serial # Y5050205) and need the unlock code. Can anyone help?
I have the same problem....
My car is a boxster with a CDR-210
the Serial # is V5015340
with a R3297 that I have no idea what represents
Can anybody help!
Loren
I'm going crazyyyyy driving to work 1 1/2 hr each way without a radio
please, help!!!!!
Edited by porsche101
Hi, could I get the code for a
Becker
CDR 220
BE 4462
SN: X5028742
EC: 111
I had to replace the ignition switch and lost the power to the radio.
Thanks Alot...
2000 Porsche Boxster....
Edited by bullseye3
Loren
Hope you can help me out as well. Never had my code but have a good excuse for disconeccting my battery. I'm currently swapping my 3.6l for a 997s 3.8l.
Becker cdr 220 ser# 15008521
Any help would be greatly appreciated.
Thank You
Loren
Thank You
Try 1574
or
1576
PLEASE HELP!!!
I need a 4 digit code for my 1999 boxster radio.
BECKER 1
TYPE: 4462
SERIAL #: W5008265
Thanks in advance.
Try 5190
or
5192
Thank you Loren! I will try and let you know the outcome...THANKS AGAIN! :)
