I have lost my radio code and do not have the card. It is a 2001 Boxster with a Becker 220 and the Type is 4462 the serial number is Y5052656 and displays a 24/99.
Try 4355
or
4357
  • Replies 18.9k
  • Created
  • Last Reply
Top Posters In This Topic
PLEASE HELP!!!
I need a 4 digit code for my 1999 boxster radio.
BECKER 1
TYPE: 4462
SERIAL #: W5008265
Thanks in advance.
Try 5190
or
5192
Thank you Loren! I will try and let you know the outcome...THANKS AGAIN! :)
5192 works GREAT!
thanks a million! :rolleyes:
by the way, which decoder program are you using?
Battery removed and radio code lost.
CDR220
model be6625
ser # 25010596
ec102
Thank you.
Tom
Try 4255
or
4257
57 Worked thank you.
ATB,
tom
Hi Loren, could you please, kindly, help me obtaining the radio code for my 99 Boxster? It's VIN is WP0ZZZ98ZXS604255
Radio: CDR-220
Model: 4362
Serial Number: X5010943
I'm just tired that my Porsche dealer in Chile says that he needs to ask for it to Germany... it has been almost 2 weeks... too much, or not? :huh:
Kindest regards, and many thanks.
Juan Eduardo
Radio: CDR-220
Model: 4362
Juan Eduardo
Try 4593
or
4591
I am new to this so be patient.
I am in need of my radio code
I have just bought another 2001 boxster s
radio: cdr220
radio ser#: 15076978
model: BE 4462
Please Help.
radio: cdr220
model: BE 4462
Please Help.
Try 1013
or
1011
Loren
Would you please help
I'm driving a 1998 porsche boxster with a CDR-210
the serial # is V5015340 and model # R3297
I need the radio code
George
Try 3026
or 3024
radio: cdr220
model: BE 4462
Please Help.
Try 1013
or
1011
Thanks, That did the trick.
Hi, usual story, lost Code
Becker 1 CDR 200 - 4467
#Y5026257
Greatly Appreciated.
Try 5004
or
5002
Sorry, didnt seem to work (and I meant to put Becker 220, dunno if that makes any difference?
Radio: CDR-220
Model: 4362
Juan Eduardo
Try 4593
or
4591
Soory, they didn't worked and I've found that the radio is a CR-220, does it chanhe the codes that you gave me? Many thanks!!! is incredible your support! Kindest regards.
Juan Eduardo
radio: cdr220
model: BE 4462
Please Help.
Try 1013
or
1011
Loren,
It seems that I was mistaken the 1011 or 1013 code does not work.
I have checked and my radio ser# is correct (15076978)
Would you be so kind as to check for the code again.
Thank you.
radio: cdr220
model: BE 4462
Please Help.
Try 1013
or
1011
Loren,
Thank you.
1013 is the code that I come up with - try codes 2 digits different from that code (i.e. 1011, 1009, 1015, 1017. etc.)
Loren
George
Try 3026
or 3024
Loren
I did try 3026 and 3024
but they don't work?
1998 boxster with a becker radio CDR 210
serial # V5015340
model R 3297
Would you please try again
Loren
George
Try 3026
or 3024
Loren
serial # V5015340
model R 3297
I got thew same result.
My program does not always work. It works maybe 95% of the time but I have no expanation why it doesn't always work.
At this point you will need to contact a dealer or Becker. Becker charges to lookup your code and some dealers do too.
radio: cdr220
model: BE 4462
Please Help.
Try 1013
or
1011
Loren,
Thank you.
Thank you it was 1015 and the radio is up and running.
hI THERE
Please i need the code for my cdr210
model no: be2282 serial v5016205
thanks in advance
Didn't work ! any other options thanks
and sorry for the pm take care
