P1182  Positive Crankcase Ventilation Output Stage – Open Circuit
Possible fault cause
- Fuse F50 faulty (fuse carrier, dashboard, on the left)
- Break in wiring in voltage supply of positive crankcase ventilation heater
- Break in wiring in connection to ground of positive crankcase ventilation heater
- Positive crankcase ventilation heater faulty (heating resistance too high)
- DME control module fault
Measure resistance between pins 1 and 2 of positive crankcase ventilation heater.
5 Ω to 13 Ω at 20 °C -- if not replace the heater.
I checked the fuses again, and the slot for fuse 50 in the left side is empty... User manual has a blank entry for it too.
Are you sure is 50 ?
And what should be the amperage ?
