Hi All,08 Boxster.Getting a P00010 CEL code. Camshaft Sensor bank1.
Is replacing the sensor usually the solution? If I clear it, it comes back in a hundred or so miles. Car runs fine but I do think it lacks a bit pick up. I'll check the wires and connector. Is there a way to test the sensor to see if its bad.. Is it possible it's the variocam solenoid?
Thanks V
Thanks V
I believe you are actually referring to a P0010, which is typically the code for an "open circuit" on that bank 1 sensor.
Yes...typo..so that would mean a wiring issue? So what is the course of action.
Probable Causes:
Control Line Circuit Open
Control Line Short Circuit to B+
Control Line Short Circuit to Ground
Fuse Faulty
Solenoid Hydraulic Valve Faulty
Voltage Supply Circuit Open
Diagnostics time..............
13 minutes ago, vza said:
Ugh...where do I start. Can you point to any sources.
Only valid resources would be the diagnostics listed on a PIWIS system as none of this information was ever in print.
Using the list I provided, you should be able to assume some basics like wiring continuity, wiring shorts to ground, voltage readings, does the cam angle change when activated via Durametric or PIWIS, etc.
You need to remember that even the OBD II diagnostics manuals for the earlier cars only provided a sense of direction, not a set of directions.  You need to get out your digital multimeter and start poking around............
Emm...I'll try find resources online about checking voltage to the connector. See what I come up with. The angle changes when watching cam angle when I accelerate w my Durametric but I was never able to activate my solenoids with my durametric. This was discussed on an earlier thread. Thanks V
Edited by vza
Well I went for a drive and the CEL was gone when I started the car. Does that mean it's intermittent and most likely a wire issue?
Checked voltage at the connector. 2 outside pins are ground with the middle at 12v with ignition on. Car running outside pin went to 14.2v,  12v in the middle and ground on the last outside pin. So one ground goes over to 14v from the DME I guess. I separated the 1st 6" of the 3 wires and twisted them around and the results stayed strong. I'll put a tone each and trace it. From what can tell by looking at the diagram the wires go to a control box left of the steering column in the footwell. Any idea where the loom or harness runs? Thanks V
Edited by vza
Well I decided to spend 22 bucks 1st and just replace the sensor. The old sensor I removed has a different bosch #. I removed bosch
0 232 103 057(Mercedes apparently)and installed
#0 232 103 092. Ran at idle for few mins CEL remained on. Should I clear the code see if it comes back or will it clear itself. Thanks V
Edited by vza
Thanks, Well the new sensor didn't change anything, threw a CEL after 145 miles. So guess it wasn't the sensor. I probed around w my new probe/tracer. Findings with engine running:
14v R/Bl right connector
12v R/Gy center "
Gnd Brn/Pink left "
Traced positive for all 3 wires from Connector to DME in the trunk(got a trace tone)
Positive continuity for all EXCEPT the R/Blu  right wire. No continuity but there was a tone when traced. Don't get it. Any thoughts? Put everything back together and CEL disappeared. Thanks V
Edited by vza
  • 3 months later...
Hi,Gettig back to my p00010 CEL ...can I just jump the wires from DME to the sensor (3 wires) to rule out the harness. Got strange results when testing continuity and using a tracer.  One wire had no continuity but the same wire pinged when using an electronic wire trace. Explained in previous post.  Thanks V
Edited by vza
Ok...do you know the part number to replace the pins in the plugs on dme side and sensor side? Would rather just make a 3pin harness and pull the pins and run the harness rather than clip wires.  Thanks v
Edited by vza
Well wait a minute. If I measure what I'm getting out of the back of the connector at the DME(back test it) and it matches what I'm getting at the sensor connector then I know it's not the harness....correct? V
Probably.  Three things to check: Check each wire for continuity from the sensor to the DME, check each wire for resistance, and check each wire for voltage drop. As harnesses age, the wire can develop internal resistance over the length, or even breaks which continuity would catch.  Resistance may not change much, but any increase in resistance can lead to voltage drop, and as most sensor are running at low or even factional voltages, the voltage at one end is different than that at the other (voltage drop), which drives these systems nuts.
Ok well here's what I found:
Wire.     Continuity.   Resis.   Vol.Drop
Red/Blu.   No.            Open.     7.4v
Red/Gry   Yes.            .3k.         None
Brwn/Pink.  Yes.        .2k.          None
Volts at DME and Sen.Plug Ignition ON
                     DME.              PLUG
Red/Blu.        5v.                  12.6v
Red/Gry.       12.8.                12.2v
Brwn/Pink.   .9mv.              1.2mv
I guess the oddest is the red/blu with no continuity but voltage when energized. Maybe it goes to a relay? Let me know what everyone thinks. Bad harness or the DME goes back to Specialized ECU. Thanks V
Did some reading seems to me red/blu has a short to voltage cause that wire supposed to stay at 5v. So maybe try replacing the red/Blu wire from DME to plug. Correct?
Edited by vza
Ok now I went into PANICK MODE. I did what I said what I was going to do...essentially replaced the red/blu 5v wire between the DME and cam pos.sensor plug and FAILURE car dosent start. Tested voltage to red/gry wire and got nothing ...supposed to be 12v. Figured I disturbed an already failing wire...replaced wire between DME and plug and now have my 12v on red/gry 5v on red/blu and ground on brwn/Pink wire (ignition on) and...FAILURE. Car cranks begins to turn over briefly but won't start. What the hell did i do. Checked all fuses in foot well the stereo fuse was blown somehow. Other than that they were all good. Please help. Thanks V
PS getting pending p0638,p2122,p2127 CELs. Throttle sensor
Edited by vza
Sorry for the delay getting back to you, took a couple days off over the holiday.
From the sound of it, you missed somewhere when you tried replacing the cam sensor wiring with jumpers.  Are you absolutely sure you traced the correct harness wires for cam sensor #1? Did you check to see if the wires from the sensor pass thru something else (another device) on the way to the DME? Using the axiom to always  go back to where you were before the problem, can you go back to the original wires or were they cut away?
Hey John...thanks for getting back. Im sure about tracing wires to the harness pins 10 and 12 for the wires i spliced. Correct volages at cam sensor plug. I don't know if they pass thru another device ...from the looks of the diagram it dosent look like they do. Wires are still there i can revert if I have to.
