Durometric pulled Tiptronic P1818 and P1823 codes after I was unable to shift into any gear on my Boxster.
There has never been any issues whatsoever with the transmission.
However, while parking my car the previous night, I accidently turned off the car while in Drive.
- At the dash with engine started, the dash correctly displays proper gear to match the shift lever, but the car does not budge.
- The mechanical linkage at the rear is all connected.
- I checked fluid level and and some fluid did come out at the fill area but the fluid is very dark with NO burnt smell.
- I reset the Tiptronic fault codes and later disconnected the battery for 30+ minutes to no avail.
--- Also, odd thing is that the Tiptronic fault codes no longer return after reset.  They show green state.
My local shop says they don't work on Tiptronics.
I read I can R&R the ATF and Filter and I am considering that myself.
However, I need a plan of attack.  I live in Riverside County California.
Please advise. Thanks.
Edited by rprieto
Added additional info
Thank you for these guides. Based on what is observed it refers me now to Chapter 11 (0-142).  Is this information available?
Odd thing is that after clearing the transmission fault codes, they have not yet reappeared. I will go through the steps here and I may also try to remove and replace the filter and ATF this weekend.
 I’m also looking for a local mechanic as my regular place does not work on Tiptronic transmissions.
Edited by rprieto
Additional information provided
