Engine light keep go on after being turned off
My engine light keeps go on after being turned off from disconnecting the battery after a few days. What can be wrong?
Is there anyway to test and see exactly what is wrong without going to the dealer? The car seems to function OK with no obvious issue.
THanks for any help.
Assuming you are talking about a CEL then you can go to Kragens, Autozone, etc. and they can hook up an OBDII reader to your car and see what codes are causing the CEL. The fact that the CEL keeps reappearing means that you have some kind of problem that needs to be addressed.
