996 TT Transmission oil
Correct, 75W-90 gear oil.
Thanks Loren.
The mechanic at the dealer said any API GL-5 rated hypoid gear oil in 75W-90 weight would be fine in the front differential. I am planning on using Red Line 75W-90 API GL-5 + Hypoid Gear Oil. I'm guessing this is a good gear oil...any comments?
I think GL5 will cause problems in the rear transaxle. It's too slippery. The levels of antifriction/antiwear additives are too high. This keeps the syncros from working properly. Redline makes GL4 oils in regular and light weight I believe.
What would be the result of using such a light gear oil other than the syncros being wierd? Would it damage anything?
Thanks Loren.
