PSE for 996 C4S
I've heard that the PSE for the C4S's were different altogether. If true then does anyone know the correct part number for the C4S? If false then, i'm assuming that any of the larger diameter bypass type PSEs would fit, no?
No difference for a C4S.
There were several PSE iterations from late 1999 until present. With the introduction of the 3.6 liter engine in MY02 they went with larger bore bypass pipes. Porsche says not to use the early small bore type on 3.6 liter cars. The later model will fit and work fine on ANY model year 996. You use original tailpipes so the fit to the later model bumper or C4S bumper does not change.
Thanks Loren.
I had heard that the PSE for the C4S were different b/c they required a longer pipe for the tips to fit.
If that's not the case, then it must be the tips that have different part numbers for the C4S vs. the others?
