hi,
I think I have the top mounting stuff intact, 2 things that spin around with nuts and bolts to attache to the trunk bottom
there's 2 threaded rods but they don't have any nuts, so I assume I need the nuts and washers for that
there's 2 spring looking parts with oops, I assume I need a nut bolt and washer for those
most importantly, as the other stuff can probably be found at a hardware store, I need to the gaskets to link the muffler to the pipes
thanks a ton,
tom
Tell us the item numbers and we will look them up.
**** you're quick! and **** that picture has a lot of parts
I'll need a #12, two #13's, two #17's, a bunch of #14's and #18's
I need to go get under my car again, it looks like the middle part of #11 maybe be on my car, the rest is on the muffler
thanks Loren!
Item 12 - 996 111 314 00 Connecting tube (2 per car) - Retail $210.28 (each) as of Dec 2005
Item 13 - 996 111 209 00 Clip (2 per car) - Retail $19.72 (each) as of Dec 2005
Item 14 - 900 380 005 09 Hex Nut M8 (8 per car) - Retail $0.50 (each) as of Dec 2005
Item 17 - 996 111 110 00 Sleeve (2 per car) - Retail $32.34 (each) as of Dec 2005
Item 18 - 900 035 004 02 Washer R9 (2 per car) - Retail $0.50 (each) as of Dec 2005
BTW... you do know that as a Contributing Member can now look up your (MSRP) prices?
thanks! nope, I didn't know I could look up prices, sweet :)
could you give me #11 too, may as well prepare myself for that cost too :)
