Instrument Cluster Problem
Loren, on my '03 C4S, the instr cluster lights have started acting up. When I turn the headlights on there is a several second delay in the cluster lighting to come on. I tried turning the switch back and forth, nothing works, now the delay in coming on is getting longer. What to do, a fuse? TIA
A couple things to look at/try...
What about the radio and climate control lights? same problem? If so, try jiggling the light switch. Could be a bad switch.
Has the cluster been opened for new gauge faces? If so, perhaps a connector is loose.
Radio, climate, speedo/computer all ok, no open cluster, guess it might be the switch.
  • 3 months later...
