flashing light from the temp gauge
Hello,
I have just taken my Porsche for a spin on the German Autobahn. As there was no speed limit I drove the car at about 160 miles for something like five minutes. Then I noticed a flashing light from the temp gauge. I found a spot where I could park the car and waited for about five minutes. The light had stopped flashing and did not go on again. According to the instruction manual a flashing light from the temp gauge indicates that the deck lid fan does not function properly.
I have already found some very useful information on this forum, so I know that the fan itself works, that the fuse is OK. I have also found the temp sensor in the engine compartment. According to one of the forum members the fan should go on when disconnecting the probe. I tried this (yes, ignition on), but nothing happened.
As to my questions. Have I forgotten anything? Is it perhaps possible to connect the two cables that go to the probe to test the fan. If it is indeed a malfunctioning probe, how do I test this? If it is the probe, how do I remove it? Any idea how much would this probe could cost?
Thanks for your help.
jo996 (the Netherlands)
Hello again,
Ever so stupid. I forgot to mention that I own a Porsche 996 C4 (November 1998)
jo996
Hello,
Hello again,
jo996
Hello,
Loren thank you for your reply. The temperature of the coolant was normal, I think. The temperature was slightly above 85 C. The red light was not on all the time. It was flashing.
jo996
The frequency of the flashing light is part of the diagnosis.
Covers all Carrera (996), GT3, TT / GT2 and Boxster (986) cars
Here is the long explanation from the service manual on the flashing coolant light.
"Four functions of the coolant warning light:
1. Engine coolant level too low -- light flashes slowly (0.5 Hz)
2. Engine compartment temperature too high -- light flashes slowly (0.5 Hz) (engine compartment blower might be faulty)
3. Engine coolant temperature too high -- light is lit; pointer on the right
4. Temperature sensor at water outlet faulty -- light flashes rapidly (1 Hz) ; pointer on the right
Note: The temperature warning in point three is indicated if the conditions "engine coolant temperature too high" and "engine coolant level too low" are present simultaneously."
Jo996,
I had the same situation, it only occured during fast driving and the temp light was blinking. It was low on coolant, about half a cup it was all that was low. The system is very sensitive and can trigger the low coolant. Do a quick fill, then take the drive from Venlo to Cologne.
