The wiper washer fliud warning came on the other day, so I duly refilled it and left the cap off overnight to allow any air trapped by the new fliud to escape. This hasn't extinguished the light which is the only light on during driving. Is there anything else I can do? Does anything nedd to be reset or checked etc. Thanks for any help or suggestions you may have- I have a c2 996 911.
Jason
Jason
bump
  • 2 years later...
If there is fluid and it still comes on then it is likely a bad connection or a bad level sensor.
I have the same problem too. Going to look at the weekend. Is the sensor accesible from the top or through the arch liner?
Easiest to just remove the wheel and wheel well liner - then everything is accessible.
Jason
