OBD II)
well, I've got the "non continuous monitor" issue again
Car = 97 993 Cab
- I have been testing various OBD scan tools to read engine parameters
trying to find something that would be suitable for this car. One
vendor I went to visit saw the Check engine light on and cleard it
before I could stop him. So, now it's a matter of hitting the exact
drive cycles to set these monitors. These are catalytic converter,
evaporative system, secondary air system, O2 system and O2 system
heater.
I have a copy of pages B3 and B4 from the porsche service manual
(Porsche faxed me these pages, they aren't in my set of factory
manuals) that describe "driving conditions for reaching readiness
code". It says that two trips must be run (that's pretty clear). It
then lists 6 cycle flags and the conditions for each.
The first is "Catalytic Converter Efficiency" (cycle flag 1). It says
"the diagnostic procedure takes a total of 300 sec. The engine must
run through 4 speed and load ranges. The procedure isinterrupted when
the engine leaves the relevant ranges and continued again when the
relevant speed and load ranges are reached again. This means that it
is not necessary to run the engine in these ranges for a continuous
period of 300 sec."
"Manual Transmission"
Engine speed: 1120 -2,800 RPM
Engine load 1.0-3.0 ms
Calculated catalytic converter temperatu4re >300C"
ok, now how the heck can I make sure I hit these conditions? I have
two OBD code readers - the one I would prefer to use is the AutoXray
6000. That tool has a readout of "load value" which may be the same
thing as "engine load", but the units of "load value" are percentage,
and the Porsche manual talks about "ms" (milliseconds?). I can
certainly monitor RPM, but what are the 4 speed ranges?
Does anyone have more information that might let me set these flags?
The last time I had this problem, the final solution was to pay a
Porsche dealer $350 to drive the car around with their tester hooked
up until all the flags set - there just has to be a better way. Does
anyone have more information, or additional relevant manual pages, or
thanks
Bill
www.wbnoble.com
Bill,
If you have time before your smog test, just go for a few drives. In normal driving, you will provide all of the necessary 'test parameters' for readiness within a couple of days.
no, that doesn't work - I know it's the theory - the last time I had this issue, I drove 3,000 miles, all types of driving, and it never set any of the non-continuous monitors. This time, it's been 4 days and about 200 miles, freeway and city driving, none have set. These monitors are obviously set in such a way that my "normal" driving does not trigger them.
well, it was somewhat tedious, but with the help of my wife, (I drove, she watched the display on the scan tool) I managed to get the monitors to set - I used the AutoXray 6000 OBD monitor to watch the engine load, and drove in the RPM range indicated in the manual for about 20 minutes, keeping the continuous driving segments as long as possible. The indicated load is very low, if you don't have the specs or a reader to show engine load, try about 30 mph in third gear with minimal throttle - you want to be between 1500 and 2000 rpm with just a tiny bit of load on the engine, just a little more than idle. And, when you start the car, let it idle until the SAI cuts off (about 120 sec) - don't know if that helped or not, but now I'm happy.
Good to know. I had to run mine about 500 miles before I got a good reading. Of course, most of this was freeway driving, so maybe that explains it.
