All Activity
This stream auto-updates
  1. Today
  2. My vehicle is pulling to the right, not a lot but notiable Alignment, four wheel: While up on the rack we Inspected steering and suspension system components. It was suggested, Connect alignment equipment to verify, and adjust front and rear wheel alignment settings , for caster, camber, and toe in/out settings. thrust angle where applicable and center steering wheel. Some vehicles may require installation of alignment shims. This can be done at one of your local Porsche maintenance shops. Im having it done for $234.70, since I don't have the equipment or knowledge to do myself. The price was right. Strut/Shock Bump Stop Assembly, front: I need to remove and replace front shock absorber bump stops, strut bearings/strut mounts. After 54k miles they are showing large cracks. I was quoted $1627.48. I have a friend in the neighborhood who is himself a pretty good mechanic. I think we can get this done for much less $$$ ourselves. On my last inspection they found nothing wrong with the rear suspension components. no unusual wear in the rear tires, but they were replaced before I purchased the vehicle. I will definitely keep my eyes open to the rear tire wear now.
  3. Yesterday
  4. I have had the same leak, at the same place. I just purchased a 2005 Boxster automatic 54k miles about a month ago. When I drove home and parked it overnight there was a small puddle passenger rear side. I looked up under the vehicle and the overflow hose was wet. I went to the trunk and there was a black cap on the expansion tank. I replaced it right away with the Blue .04 Cap. I wiped the residual coolant off the strut below the overflow hose and drove it around. I came back no leak. I thought I solved the problem, not....I took it to the dealer in town and had some overdue service's performed. They were supposed to do a pressure test on the cooling system, drain and refill. I found out later after multiply leaks that he considered the vacuum a positive test. That cost me and aggravated the hell out of me. I took it to another dealer in town. He preformed a pressure test and found it was the expansion tank leaking. I went back to the other dealer and talked to the owner. He said it was his mistake and will pay for the replacement of the expansion tank and the labor he charged me to empty and refill the system. This comimg Tuesday after replacing the expansion tank they will preform an other pressure test to see if the rest of the closed loop is ok.
  5. Last week
  6. Hello Members. I have a recent purchase 2018 Cayenne Platinum and experiencing a failed Bose amp due to roof leak. I’ve purchased the same used Bose amp model 4G5035223E from Ebay. After install, I can only get sound on the driver side. I have a scanner iCarsoft POR V3.0 but I don’t see any fix from it. A friend of mine has PIWIS 3 available but I have never used one prior. Does anyone know the fix to the above? (also.. I’ve already transferred the CMOS chip from the original amp onto the Ebay unit hoping it would satisfy the thief protection feature… but no dice. ☹) I appreciate the help!!!!!!
  7. hi Flat6Miami. did you ever get the amp working? I'm in the exact situation as your post. 5/8/26. Any info would be greatly appreciated. Tks. Anly
  8. Worked perfectly thanks again Loren really appreciate your assistance
  9. Earlier
  10. Perfect! Thanks Loren and have a great weekend!
  11. Hi Loren, Had to replace my old stereo and just got the following: Becker model BE 2182 / CR 210 Serial number V5004695 Can you help me out with a code? Much appreciated.
  12. Thanks much appreciated will do
  13. The easiest and probably cheapest way as well is to add a small amount of coolant compatible UV dye to the system and run the engine for a bit. The dye will leave a highly visible (with a UV light source) trail to exactly where it is coming from. We use this technique regularly in the shop to trace difficult leak sources.
  14. and another underneath all three hoses at the manifold (rotated to get the proper orientation -- I think)
  15. Another pic of the engine side of the tank manifold, below the rightmost hose at the manifold (I think). . .
  16. I have a 1998 Blue/Grey Boxster with 82,000 miles. The other day I got a low coolant warning, I topped it up (always keep coolant in the trunk), when I pulled back into the garage later, there was a puddle of coolant on the passenger side and at or just in front of the rear wheel well. I jacked it up to inspect from underneath and there was coolant along the rear fender-to-body pinch seam on that side, as well as a little on the rear suspension arm(s) and to the front near the underside valence cover below the thermostat-water pump. The water pump and thermostat were replaced 18ish months ago, one of the radiators a couple of years before that, so I know my way around the cooling system reasonably well -- except for the expansion tank. I checked the thermostat, water pump and the hose plumbing that goes toward the front and the radiators and the heater hoses. No sign of any leakage I checked the top of the expansion tank for signs of overflow: none. (As the overflow drain appears to go thru the tank, is a possible failure mode for this integrated-molded overflow channel to crack, allowing tank fluid directly into the overflow channel wihtout going thru the cap and onto the top of the expansion tank body?) I checked the trunk floor around the expansion tank: dry as a bone. (But I didn't pul out the carpet.) I checked the oil (in case a head gasket): golden clear (changed about 1,800 miles ago). I then popped the engine cover and poked around toward the tank manifold with a borescope: it appeared dry, though from the pics (I add as replies as there is a 2Mb limit), there appears to be moist(?) dirt all over the manifold -- but no sign of any actual liquid anywhere. Before I dive into an expansion tank project, a couple of questions: 1. Can the tank manifold leak from the engine compartment side -- all the threads and videos I've seen only show leakage on the trunk side of the tank; if so, how can I confirm it with a borescope or other method? 2. Are there other points in the engine compartment where a leak might be possible (not sure where the three lines on the expansion tank that are under pressure go) but it must be to the engine block? If so, where else should I look? Any help/advice would be much appreciated before I undertake a tank renewal that might not have been necessary. Here's a pic of the manifold body between the rightmost pipe-hose and the other two hoses also under pressure.
  17. Any chance someone can help with a code for this radio, CDR 220 seriel no 15064643 model BE 4462 thanks and best regards, Johnny
  18. Hello Loren,
    I hope you are well. Any chance you can assist me with a radio code for a CDR 220 will be greatly appreciated
  19. Thank you for the post about the 2004 horizontal motor. The 4mm hex plugs on the left and right of the pump will bleed the fluid out of the rams. Makes a mess. As called out above the fill port is on the end of the white plastic. I found it useful to move the electronics out of the way (2x screws) and then also undo the bracket to wipe down the pump and fill.
  20. Took the 987 to SOS European today. Branden tested with the PWIS and confirmed the fog lights worked, but the switch didn’t. Fortunately, I bought a switch on eBay and it worked fine. All is good now
  21. That was it! Thank you!
  22. I have lost the code for this radio in my 2000 Boxter. Any help would be greatly appreciated thanks in advance
  23. Looking for preferably a black hardtop for 2000 Boxter located within 200 miles of Seattle Washington
  24. Many times the servo is not bad but the foam from the flaps has deteriorated and jammed their movement. I would check that first then rest the codes and test before actually replacing any servos.
  1. Load more activity
