Leaderboard
Popular Content
Showing content with the highest reputation on 01/26/2021 in all areas
  1. I have installed one in my 03 turbo. 1. Make sure that you replace the following before installing: 996-552-231-12-01C Support frame for center dashboard trim in Satin Black for Porsche 986 and 996 99655265304 Retaining Bar Climate control trim 996-552-339-00-01C 1. Took me awhile to figure out how to install the PCCM retaining brackets so they are secured to the horseshoe. 2. When you re-locate your HVAC control make sure you run the harness on the right side of the dash. There is only one place where the cables will be long enough to connect to the control module. 3. The USB media box harness needs to run to the center of the dash. The harness length is way too short. It took me 15 minutes to connect the small 10 pin connector to the rear of the PCCM, connecting it by feel. 4. You will need a PST2 or PIWIS to code your ecu, if you want map data to display in the instrument display. I used my PIWIS 2 to code the navigation in the instrument control module. 5. I haven’t read any of the manuals yet, but operation is pretty straightforward. 6. I have a Bose system and the sound is amazing, as compared to the CDR23. 7. I would recommend installing a SiriusXM tuner kit. 8. If you have a MOST system, it’s basically plug and play. If not, the PCCM is problematic with grounding and sound issues.
    1 point
