Leaderboard
Popular Content
Showing content with the highest reputation on 03/17/2022 in all areas
  1. I've seen this a few times. 1st I'd say if you have a vac. gauge get that on your vac pump on the back of B1 cyl head. Look for low vac./oil ingress from pump seals. Another easy test would be if you have ability to run a short test. Remove r/r wheel & inner liner gain access to carbon canister vacuum feed line place a vacuum bleeder on the canister and run your short test. If you pass it's a vac supply issue if you fail it's a carbon canister/electrical issue. My gut is bad vacuum pump
    1 point
