  1. I have not seen any description in any shop manual. Let me have a look at Chuck Jones' car and we will try to take pics and write it up.
  2. Chuck, Yes, the fuel door is armed as part of the alarm system. If it fails to arm you will get a beep when you lock the car (the same beep you get if any other zone is "open"). I can check that fuel filler flap is the cause of the alarm beep with my PST2 (or Durametric software). If that is the cause we can see how hard it is to take the evap canister out.
  3. Is that the defroster cover next to the windshield? If so, you want both pieces, right? We will also need to know which wood (check your options list).
  4. :welcome: Try our search feature... I found this one (and about 25 more like it). http://www.renntech.org/forums/index.php?showtopic=1827
  5. Two parts... see post here.
  6. Most of the Porsche fluid is ATE. It's like spark plugs - sometimes when you get Porsche spark plugs they are Bosch and sometimes they are Beru. Bottom line is both vendors are "approved by Porsche".
  7. Could be a leaky or bad vacuum booster or a bad master cylinder. Does the pedal hold (stay hard) if you pump it up?
  8. I have discussed the feature with the Durametric folks - but it has not yet been implemented. ATE Super Blue has the same properties as ATE Typ 200 (gold) -- it is just blue in color. I would not worry about the small amount of left over fluid.
  9. The second one is a factory sport silver used in MY03 and newer Boxsters.
  10. In the US they go by Model Year -- in the UK they go my Build Year.
  11. The B&M shifter shifter instructions are quite good for this. You can download them here.
  12. Have you checked with Sunset Imports (Porsche Parts at Dealer Cost)?
  13. You could try filling the tank - then disconnect the battery for 5 minutes and then re-connect it. If that doesn't do it then you may need a PST2. It still could be a bad sensor or cluster.
  14. It is included (as an option) on US/Canada cars (at least that is what the parts list says).
  15. The misfire is only on cylinder 3? That is the only code? If so, then you likely have a cracked coil or bad spark plug. You need to have a look.
  16. From what model year? There were several versions.
  17. Either the fuel level sensor (connections) have gone bonkers or the cluster is bad. If you hook up a PST or PIWIS it should tell what the fuel level sensor is doing.
  18. Yes, it should be in the tool kit. It is used to position the wheel so you don't hit the caliper putting the wheel on.
  19. 000.044.200.12 Boxster 2.7, 3.2 liter PSE (kit)
  20. Please do not ask people to violate copyright laws. There are companies and people that sell service manuals.
  21. P1117 - Oxygen sensor heating 1 behind catalytic converter – below lower threshold P1121 - Oxygen sensor heating 2 behind catalytic converter – below lower threshold P0160 - Oxygen Sensor After Catalytic Converter (Cylinders 4 - 6) - Interruption of Signal P0153 - Aging of Oxygen Sensor Ahead of Catalytic Converter (Cylinders 4 - 6) - Below Lower Limit P1117 and P1121 say the O2 (after cat) sensor heaters are not heating. Very odd to have this on both at the same time. I would have a good look at the wiring and connectors. P0160 and P0153 are one sensor before the cat and one after - again very odd as this would say both are bad. Again could be a wiring harness issue or a bad DME. Is this a US car? Any other visible issues with the car? Does it run/idle properly?
  22. Yes, it is common. Your dealer should have replaced your cap years ago. The caps with a part number ending in "00" are all bad (or soon too leak). Porsche updated the cap and you should get the one that ends in "01".
