  1. 996.631.036.00 reflector - right side (for car without headlight washers) 996.631.036.01 reflector - right side (for car with headlight washers)
  2. I assume the tool can be had from a dealer. Any idea what it costs? Or does anyone have one I can borrow? Jeff (Tool Pants) has one.
  3. 997.111.105.00 -- exhaust manifold cylinders 1-3 (X51) 997.111.106.00 -- exhaust manifold cylinders 4-6 (X51)
  4. http://www.renntech.org/forums/index.php?showtopic=50
  5. http://www.renntech.org/forums/index.php?showtopic=7592
  6. The only reason I've seen to replace rotors is that they are beyond the wear limit or have cracks beyond spec. I suggest getting a second opinion from an independent shop in your area. You can check with your local PCA for "reputable" independent shops in your area.
  7. I can't remember if you press the tabs or pull the tabs on the sides of the radio. You don't need the keys to put it back in (just take it out).
  8. How can they tell your flywheel is bad without seeing it or testing it? Porsche had a TSB telling dealers to stop replacing flywheels that had nothing wrong with them (under warranty). Is this Niello Porsche? TSB 8/02 1360 Dual Mass Flywheel Check Procedure -- dated 12-13-2002 "Dual mass flywheels which have been returned under warranty to the Porsche AG Service Test Center are subsequently tested for proper function by the manufacturer. Test results have shown that, apart from a few exceptions, the dual mass flywheels involved in complaints are determined to be in proper working order. On page 2 you will find a check procedure for the assessment of DMFs involved in complaints."
  9. Does your window go all the way up (like it is supposed to) with the soft top?
  10. Use the Quick Menu and choose External Paint Colors.
  11. Please do not double or triple post. You posted this request THREE times. Please re-read the board Rules/Guidelines.
  12. In My Humble Opinion
  13. It depends... there are two switches on the clutch pedal. One switch for the start interlock and one for cruise control. If the clicking is "heavier" than a switch or there is any binding then something else is wrong.
  14. Where is the engine from? Factory rebuilt? 3rd party? What kind of warranty will they offer?
  15. http://www.renntech.org/forums/index.php?s...ost&p=17285
  16. Unless the Actron has changed it can not turn off air bag codes. Where are you located? Perhaps someone close has tool to clear it for you.
  17. You left the key in the ignition didn't you? ;) When you put the key in the ignition switch it activated the air bag circuit (without turning it). You will need the Durametric Software, a PST2 or PIWIS tester to turn the air bag light off.
  18. I don't Porsche makes them available for US dealers stock anymore (that was the last I heard). You might get lucky and find a dealer with some still in stock or get a dealer to order from Europe.
  19. IMHO... not unless someone put in the wrong spark plugs.
  20. See the quick solution here.
  21. Okay, this problem is now fixed. Sorry, for the inconvenience. If you want to correct the problem immediately (instead of waiting for your cookie to timeout) just: 1. Clear cookies in your browser for RennTech.org. 2. Delete your browser cache and close your browser. 3. Re-open your browser and login again. You should now stay logged in unless you don't visit the site within 7 days (most folks do).
  22. Sure... you could break the window, jam the window, tear up the rubber molding, etc., etc. The fit around the window is critical to the it closing properly, not leaking, not causing noise. So adjustments should be made very carefully (IMHO).
  23. Sorry, the problem of not remembering you after closing your browser is a new problem with the board. The company that makes the software just did an update to the software and that got broken somehow in the process. I suspect they will have a fix for it sometime early next week. Please be patient until then.
