  1. I don't know how many miles on your car but unless it is new I would replace the gaskets. I would also replace the nuts as I think they are self crimping - so once they've been taken off and put back on they can loosen. The gaskets retail for about $25 each and the nuts are $3 each. Also, as I recall a local guy did this and one or more of the studs (through the turbo and the muffler) snapped off - with all the heat down there I don't think that is too rare. So, you might want to be ready for that occurrence. It would likely make it a bit easier with the bumper off... I think it all depends on your wrench (spanner?) assortment. Good Luck!
  2. http://www.renntech.org/forums/index.php?showtopic=1512
  3. Shaft seal (listed) is the RMS seal - that is not the latest part number though. The latest part number for the RMS seal is 997 101 212 00. Their CEL fix sounds like a shotgun approach ($$$). It most likely is the MAF and the idle speed valve likely just needs cleaning (IMHO).
  4. The pic below is from the current (latest) parts list. The difference between 5 and 6 is one heat range. As you can see for MY02 and newer it's: FGR 5KQE0
  5. I pulled the CD holder out and can see an "unattached" wire connector with 4 wires. I guess this could be for many connections? Have a look at this thread.
  6. We have updated the MY06 Carrera S order guide for both US and Canada. We have also added the MY06 911 Club Coupe for the US. Added on August 31, 2005: MY06 Carrera 4 Coupe/Cabriolet for US and Canada and MY06 Carrera 4S Coupe/Cabriolet for US and Canada.
  7. On your cars option list which telephone prep do you have? M193/553 or M618?
  8. 996 552 335 02 01C Console trim for 2 switches (satin black) - retail $6.82
  9. Again, what color? what trim? They come in black plastic, or several leather trims - each is a different part number.
  10. There is also a DIY here.
  11. Yup... the photographs courtesy of Greg Heumann were taken on a TT.
  12. We have just added some MY06 Owners Manuals. They are: Boxster, Boxster S (987) Carrera, Carrera S, Carrera 4, Carrera 4S (997) Cayenne (V6), Cayenne S Cayenne Turbo Special thank you to Viken!
  13. For what model year and what trim? (There are 12 in the parts list).
  14. Solid is better (as if any CEL is good). Flashing means you should not drive car as there is potential damage to the three way catalytic converter. Solid means you have fault code of something that needs correcting or possibly will correct on it's own (after a number of drive cycles).
  15. Are you sure that you didn't knock a vacuum hose loose or forget to tighten a clamp? (around the tank)
  16. ... or perhaps your 3rd stop light does have a problem?
  17. :lol: Everything is kept in the database by member number (i.e. posts, cars in the garage, messages, polls, preferences, message subscription, etc., etc.) - so it would be a real pain to try and trade numbers.
  18. When you pull on the emergency cable can you feel it put the latch back? I don't understand how the primary release and the emergency release would both fail - unless it were jammed. Have you tried (gently) pushing down while you work the release(s)? I seem to remember Tool Pants or a tech tell about an emergency cable that would not work and they had to fish in there with a snake like grabber to pull the latch - as I recall they said it took hours.
  19. The copy of the parts list I have shows 3 self tapping screws (per side) for the armrest. If that is what you mean they are 4.8 x 16. 900 143 046 02 self tapping screw and retail for $0.29 each.
  20. That is a removal pic - he has already disconnected it from the pump.
  21. Well, you might try pressing down on the front bumper cover it will give a small amount. Perhaps then if the latch is releasing you could slide a thin piece of plastic under the red lever and move it to release the secondary latch. Did someone slap the trunk perhaps damaging the latch or moving it down in it's adjustment?
  22. Does it move at all?
  23. From an August 26, 2005 sales memo...
  24. You don't need to be PCGB club member to access the site - you just have to register (like here). I can see the message fine.
  25. Yes, custom for every car. The schematics always show a fully configured car - which very few are. Porsche simple does not put in wires for options that were not ordered (i.e. PSE, Xenon, etc.). Probably save them a few dollars in costs - but costs them in the retrofit market.
