  1. I've had SO-3's on my car for two years and am happy them.
  2. Actually the Boxster is not on the list:
  3. MY99 C2 or C4? MY99 C2 is throttle cable so there is no software to upgrade. MY99 C4 is e-gas and there may be an update that will work.
  4. The Transmission oil change instructions come from the Porsche Service Manual so perhaps some of the early cars had these covers. Sounds like everything is there... Underbody Covers (current cars)
  5. From the Mobil 1 website: Since I have two of the cars on their short list that were broken in on Mobil 1 -- I tend to agree. I would however make my first oil change at the end of the break in period.
  6. Oh my, my... perhaps you should look for a new dealer. The current PSE fits ALL model 996's regardless of year or engine type. It even says that in the Tequipment catalog and the Porsche Parts List. I'll send you an email...
  7. Sorry I was not clear. The drain tube (usually a rubber hose) should be right under the firewall or just a little further back towards the center of the car. Yeah, I meant passenger side of the battery.
  8. Two things to try... 1. Find the A/C condensation drain tube under the car and pass a stiff wire through it to make sure it is not plugged. Also, have a look at the drain just the left of the battery (in the front trunk) and make sure it is not blocked either. 2. To get rid of the current odor... get the car fully warmed up (or hot even) then open all the windows and turn the heater up all the way (blower as low as it will go). This heat will kill the stuff growing in there. I tried this on my wife's Jeep when the A/C condensation drain on it plugged and it worked pretty well. If you live in a humid area then try shutting the A/C off a mile so from home so the condensation has a chance to evaporate before the car sits in the garage all night. Good Luck! :beer:
  9. Yes. 996 511 011 02 has been the same front hood on Boxster and Carrera from the first production through today.
  10. Yes. The rear has drop links also. Unlike the GT3 they are not adjustable.
  11. 996 512 988 00 Spoiler It is held in place with double stick tape so you only get one try to get it right. My Nov 2003 price list says (are you sitting down?) - $364.86 (retail).
  12. No not really. The industry wide OBD II codes are supported by many generic scan tools... but the Porsche proprietary specialized codes and programming interface in the PST2 can only had in that device. BTW... a PST2 can be purchased by independent shops for about $8000 plus a yearly subscription to software updates for another $2500/year. Also, Gert wrote a message a few weeks ago about Porsche switching over to a new device. Gert's message
  13. The price includes the connecting cable.
  14. This is what I use on my laptop. Nothing fancy - nothing expensive. $122 Car Code OBD-II
  15. Is this the standard cap? If so try 996 361 505 11 9A1.
  16. PST2 is the Porsche Diagnostic and Programming tool.
  17. Yes, just ask your dealer to turn on the OBC using his PST2. Temperature display is the default so even if you don't have the stalk to control the other OBC functions you will still get the temperature.
  18. Yes. I have installed these on a friends car and they work fine. PSE does not change any of the geometry, if they fit your current muffler/rear bumper then they will mount the same way on the PSE.
  19. Can you tell me a little more about what it would include?
  20. 986 552 995 09 designates a rear center console painted to an external color... so you would need to specify color (this is the same as factory option XME). Likewise the 000 044 802 25 kit (I believe) specifies ash tray etc. in arctic silver as it is a Tequment package.
  21. It's the prewired phone connector. Brown = Ground Red / Green = Switched 12 volts Green / Black = Unswitched 12 volts Yellow / Black = Telephone Mute (Jeff's pic)
  22. A little more info.... The MY03 Cayenne's (until April 28th, 2003) all had Auxilary Batteries and TSB 1/03 2706 describes how to install it. After that Porsche moved the Auxilary Battery to an option status (Option J2C) for MY04 cars (TSB 2/03 2706). So the good news/bad news is that if you have a MY03 you likely got the 2nd battery included and the MY04's will only have it (and the wiring harness) if it was ordered as an option.
  23. 1. Lever off locking button with an a hard plastic tool (to prevent scratches). The locking button must be pressed so that the pipe section can be inserted between the shift lever and the locking button. To do this, turn the ignition key to "1" position. 2. Remove the compression spring (1) and spring clip (2)and pull off the selector knob. Install is the reverse. Make sure you fit the conical compression spring with the small diameter facing the guide peg.
