  1. It might work but the buttons and deign are for a MY03 and newer cars with the matt black finish. Your car is the last year of the glossy finish buttons and trim.
  2. The simple test is the buy/borrow a micrometer and see if the rotor thickness is within spec. You can also check the runout. If they are within 1 mm of the minimum spec I usually change them out. Remember SUVs are a very heavy vehicle and it will go through front rotors. My wife's SUV (Jeep) was the same way, the factory rotors barely lasted 25,000 miles. I put a set of Brembos on and now have 75,000 miles on them and are still with spec.
  3. http://www.renntech.org/forums/index.php?showtopic=6203
  4. That maybe close but he has a 987 -- not a 986. It is similar but not quite the same.
  5. Would a CDC-3 work in place of a CDC-4 or is it incompatible? I have a CDC-3 that is in good working order. Nope, CDC-4 is MOST (fiber optic) interface - CDC-3 is wired. So, CDC-4 only works with MOST radios.
  6. Did you look here?
  7. 6 speed or Tiptronic? 6 speed oil smells like transmission oil (strong). Tiptronic fluid is red and lighter weight than motor oil or manual gearbox oil. Look at the DIY diagrams for oil change and manual transmission oil change (assuming your car is a 6 speed) and see which looks like the drain you removed. This is the oil drain plug - an 8 mm hex (as I recall). The clean area.
  8. :welcome: Model and year of your car please...
  9. Yes, it is similar. It still sits high on the transmission near the bell housing. Remember PentoSin for the clutch circuit on TT/GT2. Ah thanks. I'm sorry but Pento-who? The 996TT DIY section is empty... I can't find any info. It's for a friend's car and I'll be helping him with the fluids. Look in your Owners Manual the clutch and power steering use only Pentosin CHF 202 (Pentosin CHF 202 supersedes CHF 11S and they can be mixed).
  10. P0413 Electric change-over valve - open circuit Possible fault cause: - Wiring harness - Electric change-over valve - DME control module faulty P0418 Secondary air injection pump - open circuit Possible fault cause: - Wiring harness - Relay faulty - DME control module faulty P1674 Engine compartment purge fan output stage - open circuit Possible fault cause: - Open circuit - Relay faulty - DME control module faulty Do you do an adaption for the DME after programming? Switch on the ignition - Wait one minute. Do not press the accelerator - Switch off the ignition for at least 10 seconds - Read out the fault memory Check the fuses and the relays - otherwise you may have smoked the DME.
  11. You reach behind the wheel liner on that side with a hook and pull it - emergency front hood release.
  12. Yes, it is similar. It still sits high on the transmission near the bell housing. Remember PentoSin for the clutch circuit on TT/GT2.
  13. Try 5571 or 5569
  14. I think you need a second opinion (quote)... that looks way high to me.
  15. How old is your battery? If it is 4 years or older it likely needs replacing. Start there. If you are positive the battery is good then measure the charging voltage when the engine is running - it should be close to 14 volts.
  16. :welcome: 1. Not unusual - but not too common either. I have heard of a few. 2. The previous may or may not have abused it. They should be able to tell when they open it up and see the other gears. 3. As far as I know 2nd gear is the problem gear. 4. That would depend on where you are located - some dealer stock GT3 parts for their racing customers others on order when needed. BTW... 10-14 days is pretty good from Germany. Try waiting 6-10 weeks for special Exclusive options (i.e. leather, etc.). Have them go through the transmission and hopefully give you a warranty on it and then enjoy the car.
  17. Bad news... all Porsches have a custom wiring harness that is made to the original order spec. That means you would have a lot of work to add in the wiring - not that it can't be done - it will be a lot of work though.
  18. There is a TSB (16/07 2820 Bar Ignition Modules (Coils) -- dated Jul 5, 2007) that states that all the older style coils should be replaced with the newer style (948.602.104.03). if your car is under warranty - this would be free to you. If not, it is still highly recommended. If you have broken one off you will need tweezers (or compressed air with safety glasses) to carefully remove the pieces.
  19. PIWIS (Porsche Integrated Workshop Information System) A special computer used by dealers and shops to program and test various control systems in Porsche cars. A PIWIS costs about $18,000 for the first year of the lease and about $12,000 per year thereafter.... so only the larger shops have it.
  20. I am pretty sure that needs to be re-programed with a PIWIS tester.
  21. The leak below the the crankshaft is the IMS (intermediate shaft seal). When they replace that they should use new micro-encapsulated bolts (or it will leak again). You should not have to re-map your DME but it would be wise to reset it by removing the battery for 5 minutes so that that it can re-learn it's adaptation.
  22. :welcome: You don't want to know... :o I bought a used PST2 for about $3600. A PIWIS lease is $18,000 for the first year and $12,000 per year thereafter.
  23. Hmm... I don't know if it will work without a code. A CDR-23 is a MOST bus (fiber optic) radio and it expects to get its code from the DME. One of the older radios would likely be an easier update (i.e. CDR-220).
  24. Yes, I use the K&N charger - then wrap it in newspaper overnight to absorb the excess oil.
