  1. No sometimes my program does not work. One more... try 3363
  2. Did you check the separate headlight fuses - there is one for each side.
  3. There is a (15 page) TSB that describes installation for MY2007 and newer cars WITH PCM. I do not know if that means you can not install it in a MY06 car. You might need a PCM upgrade to install it.
  4. The EVAP canister in a a 997 is quite different than a 996. It is a rectangular box that sits in the trunk. But the functions are the same. If you disconnect it from it's mounting screws and then disconnect the electrical and vapor lines then it should come right out.
  5. If the battery is over 4 years old replace it. Have the battery tested and charged. If the problem continues I would suspect the ignition switch is bad.
  6. Exact Model? Model Year? Country?
  7. I would get it to a shop with a PST2 or PIWIS tester and have them test the sending unit circuit.
  8. More likely your code reader? What are you using?
  9. These items have been available here to Contributing Members for some time.
  10. Please try using our search feature as this has been covered before.
  11. Please try using our search feature as these have been covered before.
  12. WKD.924.021.87 Owners Manual -- $62.53 (Canadian) at your dealer Try PMing member Porschelibrarian - he may be able to find a 924 service manual.
  13. TSBs sometimes cover accessory installations (like Sport Exhaust, CDC-4 CD Changer, Telephone, etc., etc.) - but there is not a TSB on the steering wheel. Perhaps that is because it is covered in the service manual. There is nothing special about removing the steering wheel - once the airbag is safely removed.
  14. Sorry, but I have no idea what you are looking for. Do you want an owners manual, a service manual? or a schematic or ?
  15. We have added and/or updated TSBs in the following categories today (36 total): Boxster (987) - 7 Cayman (987c) - 4 Carrera (997) - 8 Cayenne - 13 GT3 (997) - 1 TT (997) - 3
  16. The bumperettes are held on by clips from the back side of the bumper. You will need to remove the bumper to remove them. What are you going to do with the holes that are left?
  17. What model year do you need a diagram for?
  18. I think it just snaps on the seat frame.
  19. Technically that is "tire mounting paste".
  20. On the seat mounting at the front (item 13).
  21. The DIY is here (finally).. Replacing the Gas Door Actuator, for Carrera (996) or Boxster (986)
  22. It is the cover that hides the seat position control box.
  23. Note: Part numbers sometimes change without notice. Always double check with your supplier that you have the latest part numbers. (Special thanks to Chuck Jones for being the guinea pig and for taking the photos.) Parts you will need: 997.624.113.00 Actuator Tools you will need: Very short Torx T20 driver and right angle ratchet or tool to use the short T20 in a very confined space Regular screwdriver, phillips screw driver, and 10 mm wrench to remove th wheel well liner 1. Jack the car so that right front wheel is off the ground and secure it with a jack stand. Remove the right front wheel. 2. Remove the wheel well liner by removing the the plastics rivets (pry them out with a regular screwdriver). As well remove the 10 mm nuts on each side of the axle. Now remove the phillips screws that fasten the wheel well liner under the front bumper and remove the wheel well liner (and set aside). 3. Locate the EVAP canister and remove the electrical connection at the top of the canister. Now remove the 10 mm nut that holds the canister in place. Remove gas the vapor lines - one at the top and one at the bottom (again by squeezing the connectors). Remove the EVAP canister by pulling gently back and forth until it releases from the rubber gromments 4. Look back up under the fender (now that the canister is out of the way) and locate the broken actuator. Now using the stubby Torx T-20 loose (but do not remove) the two T-20 screws. The actuator itself is a bit tough to get to and you will need a really short T-20 Torx head to loosen the two screws. I say loosen because that is all you need to do to remove the part - it sits in two "U" shaped slots. Remove the electrical connector (by squeezing the tab). Here is a pic of the new part - as you see the Torx screws are already in place so that is all you have to do to replace it. 5. Put the new part in place making sure you feed the emergency pull line through the fender to its location in the door jam. There is room to slide it through the side so you don't need to try and thread it through the hole. Fasten the two Torx screws and reconnect the electrical connector. Chuck's car had the guide rose guide piece missing (so he needed to order one) Here is a pic of his car (without guide rose) and my car (with guide rose). Ref. P/N 997.624.505.00 We also noticed that on his car the plastic catch for the lock was missing (so he needed to order that too). Here is a pic of his car (without cap) and my car (with cap). Ref. P/N 996.201.243.00 6. Reinstall the EVAP canister by pushing it into place on the rubber gromments. Then reattach the vapor lines (they should snap back into place) and the electrical connection. Finally put the 10 mm nut back in place and tighten down. 7. Reinstall the wheel well liner (reverse of removal). 8. Mount the tire, lower the car and re-torque the wheel bolts. Done.
