  1. Knocking, rattling, sqealing... etc.
  2. Do you mean the dealer/shop code in a PST2?
  3. Measuring point front axle The distance (middle of wheel) between the road (wheel contact area measuring platform) and the measuring point A on the axle support is measured. Rear axle measuring point The distance (middle of wheel) between the road (wheel contact area measuring platform) and the measuring point A on the axle support is measured.
  4. Do you know the measuring points? If not I will post that too.
  5. Well, without a PST2 the only things I can think of is to listen to compressor for a worn bearing and also the front radiator fans. The radiator fans should kick up to stage 2 (high) whenever the AC is on. Also, the RPM should come up about 100-200 RPM. With a PST2 (or PIWIS) there are about 2 dozen items you can check and test.
  6. Carrera engines do not turn in the opposite direction - they are mounted facing 180 degrees opposite direction. The difference is in the differential which puts the ring gear on the opposite side in a Boxster. That is how the drive direction is corrected.
  7. PM me if you want a copy of the older (epoxy) installation instructions...
  8. http://www.renntech.org/forums/index.php?showtopic=3922 http://www.renntech.org/forums/index.php?showtopic=1149 http://www.renntech.org/forums/index.php?showtopic=166
  9. When the sideskirts are done properly there should be no gap at all. That is, you can not even slide a piece of paper in the place where they meet. The later version of sideskirts Porsche sold had two-sided tape where as the early version was put on with epoxy. I think one of the complaints was that the epoxy version needed to taped and held in place for 24 hours before the car could be driven. The later version of the double sided tape does not seem to to hold as tight as the epoxy - IMHO. Here is a picture of my factory epoxied sideskirts.
  10. At the top of every page is Porsche Parts at Dealer Cost. Email or talk to Jeff in parts - I'm sure they can take care of you.
  11. At this point it does not look like it. I think you might have to pay for the Adobe Acrobat (PDF) files from Porsche Technical Information website. In the US they cost $110 per manual section or $5200/per year. They show the 997 wiring diagrams are available there for $110. Just remember what you get for $110 is what is "currently" available if they update or correct that section of the manual you have to pay the full price again to get the updates. Porsche is charging 3 to 10 times more that other manufacturers for this type of data (even more than Mercedes!)... In the US they are currently required by law to make this information available - unfortunately the law only "suggests" a reasonable cost for access to it. Please don't get me started on this as I have a very strong opinion on that... :angry: :angry: :angry:
  12. PIWIS - about 18,000 USD per year to lease.
  13. Contributing Members can view TSBs online as well as a Contributors Only Forum, they can send attachments with PMs, image storage limits are raised for all Contributing Members, RennTech.org email addresses are available and now a personal Blog.
  14. The fronts should be fine - as long as you go with a 235 or smaller tire. 245's will rub and some brands of 235 may rub slightly on a 9" front wheel. On the rear you will need large spacers or different wheels. The offset for the rear with a 10" and 285 tires should be 63 mm - so you are about 18 mm off. Other folks might have some input too...
  15. Oct. 8th - Looks like I'll be there with my PST2 and other stuff to help out. I haven't heard back from Jeff (Tool Pants) yet though. Once this gets confirmed please either post a map or give an address we can use for directions. Thanks!
  16. http://www.renntech.org/forums/index.php?s...findpost&p=3513
  17. I just tried the article link and it works fine (over 200 downloads as of today). The article and pics are hosted here (by permission). You will need Adobe Acrobat Reader (free) to read the article.
  18. Just a vent line that goes nowhere. Nothing to worry about.
  19. Did you check the intermittent wiper relay (position 16)?
  20. I have the preliminary 997 service manual and the wiring diagrams are not in it yet - so I doubt the 987 wiring diagrams are out yet either. In the past they have usually come out 8-10 months after the first car ships. I'll keep my eyes open though...
  21. The last owners manual I ordered through Sunset Porsche (Porsche Parts at Dealer Cost) was $18.
  22. I don't know that it can be unlocked and then relocked... or perhaps reprogrammed and then locked? I guess you won't know until you try. If not, then you will need a new trigger unit..
