  1. Scouser... is the bucket part of an elaborate alarm system? :lol: :lol: :lol:
  2. Yes, that is the default setting on your MY car if the OBC has been enables. Otherwise that display would be blank.
  3. XE8 - Gear lever in dark burl walnutr with aluminum inlay XE9 - Handbrake in dark burl walnutr with aluminum inlay 502 - Made in Finland 537 - Seating positon control - comfort seats - left 584 - Storage box behind seats 981 - Leather equipment without seat covers 983 - Seat covers in leather - front
  4. 2004 C4S Cab - North America version C02 - Equipped with catalytic converter XCZ - Switch travel shortening XNR - Central air vent in carbon XNX - Trim strip in carbon XP4 - ??? XSC - Porsche crest embossed in headrest XJ4 - Ignition lock surround in leather X47 - ??? X54 - Stainless Steel Exhaust Pipes X58 - ??? 265 - Automatic anti-dazzle mirror with rain sensor 266 - Automatic anti-dazzle exterior mirror 288 - Headlight washers 342 - Seat heating left/right 375 - Sport seat backrests 09991 - Manufacture from the exclusive-programme
  5. No, I don't but almost everything is T15, T20 or T30. I think T30 is way too big so they are likely T15 or T20. I think Sears sells a nice small set of Torx with screwdriver handles.
  6. Yes, the emergency pull cord for the front hood is behind the right front wheel well. Most shops and dealers know how to get to it. The fuel lid will not open for the same reason - it is electric. The fuel door is locked (and alarmed) when your car is locked.
  7. The stock two-tone horn is on it's own 25A circuit so you could always bump the fuse up a little.
  8. Becker North America Phone mute/Aux audio-in/Tel audio-in/Radio Removal keys in one kit is, BNA-116.276 ($16.40) To order call (888) 423-3537 x1209
  9. Use a charger that works through the lighter and that will likely have enough power to open the front trunk. Later model cars have a similar jumper point on the fuse panel (in the drivers footwell). If all else fails you can use the emergency manual release behind the passenger side headlight. Do a search here if you have trouble finding the emergency release cable.
  10. Very, nice! You do know that you can have multiple pics per message - up to your 250k limit?
  11. C02 - Equipped with catalytic converter 198 - Starter 1.7 kw 232 - 17" tires 249 - Tiptronic transmission 394 - Boxster 17" wheels 432 - Steering wheel with Tiptronic controls 454 - Automatic Speed Control 490 - Sound System (Harmon I think) 502 - Made in Finland 535 - Anti-theft lock 315 mhz 551 - Wind deflector 584 - Storage box behind seats
  12. The US and Canada MY2006 Boxster order guides are not out yet. There is a sales bulletin (from May 2005) that says TPMS will be available on MY2006 997 (option 482) but does not mention 987.
  13. I think the issue is cross-threading.
  14. Here is a link to a small really easy to use FREE program. IrfanView Just go to Image - Image Resize/Resample then set the image size to something like 800 x 600 and set the DPI to 72. Then Save As and you are done.
  15. Most likely, certainly worth a try. The TSB is for "BOSE amplifier - Sporadic sound failure in vehicles with PCM2 (I No. 8DV, 8DQ) and BOSE sound package (I No. 9VL". It involves a software update to the BOSE amplifier. In some cases I've heard they replaced the CDR-23 also.
  16. 996 537 085 07 Outer Left door gasket - retail $207.07 996 537 086 07 Outer Right door gasket - retail $207.07
  17. Not according to the TSB for the Aerokit Cup or Aerokit II. C4S, GT2, GT3, TT all get two struts but regular C2 and C4 do not... go figure I have a factory installed Aerokit on my MY99 car and one strut has held just fine.
  18. You can get a very high quality image suitable for posting that is under 100k. Regular members are limited to 250k per post. Contributing Members get 1000k (1MB) per post. How big are your images?
  19. There is a (non-printable) list in the Porsche parts catalog -- by model - by year. It usually has 99.5% of them. If you want help on these then I will need to know exact model, year and US/Canada car or RoW car.
  20. No, not sealed. Porsche does not supply internal parts for either the 5 speed or 6 speed Boxster/Carrera transmissions. Only limited parts are available for the GT3 transmission (mainly gear sets). Porsche claims that it is cheaper and better for the customer to get a rebuilt (exchange) transmission from their vendor.
  21. 1. Remove the door panel to gain access to the holding clip. 2. Press out clip with a plastic spatula. 3. Pull off door seal on the outside. 4. Carefully pull the seal out of the clips along the door contour. First position door seal on the outside at the top edge of the door and push it on. Rest of the installation is the reverse of above.
  22. All the rest of those parts on the that list ("Brake Pads for Racing Circuit Use") are Porsche Motorsports part numbers. Sorry...
  23. I guess so... thew parts list does not show the felt covers.
