  1. Yes. If you follow the belt down to the carpet there is a large bolt under a plastic cap. Remove the plastic cap and then remove the bolt (remember the order of any washers or spacers). This should allow you to manipulate the belt through the rose.
  2. Pics would be great and if you have any dimensions on the mounting plate that would be really helpful too. Thanks! :cheers:
  3. This likely needs some testing but give it a try (if you want). Door Panel Removal/Install Instructions
  4. Is it the lead that plugs into the relay sockets?
  5. Yes you can likely get it in Savanna. But, as Gert said we need to know the type of seats (sport, comfort, or standard). p.s. We know your car is a MY99 Cab ;)
  6. Note: - The following values relate to the empty weight, i.e. full fuel tank, vehicle with spare wheel/collapsible wheel and tools, but without driver and without additional weights. - X74 = 30 mm lower. This can be identified by 1 yellow mark on the shock absorber. Note: - The following values relate to the empty weight, i.e. full fuel tank, vehicle with spare wheel/collapsible wheel and tools, but without driver and without additional weights. - X74 = 30 mm lower. This can be identified by 1 yellow mark on the shock absorber. - A caster adjustment is normally not necessary and is therefore not present! If required in a customer service matter, a caster adjuster may be installed (Serv. No. 40 19 23/Installing caster eccentrics). - The toe-difference angle value is also influenced by the vehicle height! For this reason the measured result must be evaluated accordingly! No action is necessary in the case of small deviations from the toe-difference angle required value, as long as the value to the right and the left is almost the same.
  7. Joel Reiser just answered this question at the PCA website. (BTW... 986 and 996 use the same coolant). Here is what he had to say about coolant:
  8. The front bumper removal and installation is covered in my DIY for the 3rd Radiator Install. This should have everything they need. Be sure and get some before and after pics! :jump:
  9. Model -- Manual -- Tiptronic Boxster -- 2811 -- 2936 Boxster S -- 2911 -- 2993 Carrera (Coupe) -- 2959 -- 3080 Carrera (Targa) -- 3119 -- 3240 Carrera (Cab) -- 3135 -- 3256 Carrera 4 (Cab) -- 3267 -- 3388 Carrera 4S -- 3240 -- 3361 GT2 -- 3168 -- n/a GT3 -- 3043 -- n/a TT -- 3388 -- 3487 Carrera GT -- 3042 -- n/a Cayenne S -- n/a -- 4949 Cayenne TT -- n/a -- 5192 Note: all are MY03 except GT3 and C GT which are MY04
  10. Chad, Here is a link to a large (2.5 MB) PDF file for steering wheel removal and OBC hack. You may not need the OBC hack but the steering info is good. Steering Wheel and OBC Hack
  11. The tank is on the right (passenger) side of the car. My understanding is you would need to drain the oil from the bottom of each turbo and that it is an 8 mm hex bolt. Sorry, I do not have a picture or diagram. I'm trying to arrange to take pics with a local guy on his TT oil change. BYW... even after draining all three there is still 4 liters of oil in the engine.
  12. IMHO Yes. Here is why I think so... The X51 beefs up the engine, oil system and cooling. Here is a short list: - new intake manifold with modified cross-section (material: sand cast aluminium ); - new intake pipe supports adapted to the form of the intake manifold; - new exhaust manifolds with larger cross-section and optimized flow behavior; - new cylinder heads with optimized, CNC-milled inlet ducts; - new camshafts with larger valve stroke on the inlet side and modified inlet and outlet timing; - inlet valve springs adapted to the enlarged valve stroke; - modified partition box in the oil pan; - modified maps for the DME control module. - new underside panel in the transmission area; - additional radiator in connection with modified front spoiler, except on the 911 Carrera 4S (996). or you could always go with the new GT3 where you get the base for the R and RS racer cars... or better yet a cup car ;) wait I guess that is not streetable... darn :rolleyes:
  13. JayM, I sent you (via email) a link to a draft of TT oil change instructions. Have a look and tell me where it can be improved. Thanks! :beer:
  14. Ben, 3.4 liter or 3.6 liter? Option on a new car? or add on to existing car? :huh:
  15. Jonathan, Here is an online source I found. Not the least expensive but they do have stock and free shipping. 1st Optima Battery Sales
  16. Jonathan, If you look at his pictures... the original (Porsche) battery has the positive terminal on the passenger side of the car closest to the windshield. When the guy in the article mounted the Optima Red Top battery the positive post was still on the passenger side but to the trunk side. So, my point is that if you got the Orange Top Reverse Post battery the posts would be in the original postion (passenger side - closest to the windshield)... perhaps allowing you to use the existing cable. Or maybe it is still too short... we won't know till we try ;) BTW... I agree with the centering of the battery on the plate.
  17. Updated August 18, 2003 Here is an updated list of TSBs for the Cayenne: 03.. 2/03 Control Unit Replacement/Software Update 5-23-03 0335 2/02 Voltage Supply During Diagnosis 2-28-03 0335 0305 Creation of OBD II Reports 6-27-03 9660 4/02 Battery Disconnect Switch 2-28-03 1001 2/02 Engine Repairs 2-28-03 1701 3/02 Engine Oils Approved by Porsche 5-23-03 2706 2/02 Battery Charging During Workshop Visits 2-28-03 2706 3/02 Battery Maintenance Checklist 3-7-03 2706 1/03 Auxiliary Battery For The Cayenne 2-28-03 2706 2/03 Auxiliary Battery Omitted 6-27-03 3735 2/02 Tiptronic Repairs 6-27-03 3965 3/02 Transmission Repairs 2-28-03 3965 2/03 Approved Oils - Final Drives and Transfer Case 5-23-03 4316 1/03 Level Control System Control Unit 2-28-03 4316 2/03 Level Control System Calibration 2-28-03 4440 2/02 Summer Tires and Wheels 2-28-03 4440 3/02 Winter Tires and Wheels 2-28-03 4464 7/03 Spare Wheel Cover Installation Instructions 7-25-03 * 6331 7/03 Cleaning Rear Bumper Stainless Steel Protective Strip 5-23-03 6692 3/02 Roof Box For Transport System 2-28-03 6692 5/03 Surfboard Rack For RTS System 6-27-03 6692 6/03 Bike Rack For RTS System 6-27-03 6832 4/03 Cool-Bag Installation and Use Instructions 2-28-03 6845 3/03 Luggage Partition Grill 2-28-03 6845 1/03 Cayenne Cargo Organizer System Installation Instructions 5-23-03 9110 3/02 PCM2: Start Screen Visible For A Long Time 2-28-03 9112 2/02 PCM2: No Destination Input Possible 2-28-03 9294 7/03 Rear Window Washing System Spray Nozzle Drip 7-25-03 * 9666 3/03 Entry & Drive System Fault Types 5-23-03 9666 5/03 Remote Control For Central Locking System Not Functioning - Engine Shutdown Not Possible 6-27-03 * New this month ** Updated this month
  18. Well, there is are two TSBs for this so your dealer may still do it for free. Certainly worth asking about. If you want the TSBs with the part numbers and instructions, email me or join the forum so I can email you. Thanks and welcome to RennTech!
  19. Specs on the 34R Reverse Post Orange Top (identical to the 34/78 Red Top): Volts: 12 Amp Hours: 55 CCA @ 0° F: 750 CCA @ 32° F: 980 J240 Life Cycle: 10-12,000 Deep Cycles: ~50 Reserve Minutes: 104 Physical Size L" x W" x H": 10 x 6.8 x 7.8 Weight Lbs.: 38.8
  20. Ok, your oil change page is ready for testing... Gt3/TT/GT2 Oil Change page I am not sure on the engine drain plug part number -- please verify with your dealer (and let me know). Also, let me know the wrench sizes if you can...
  21. I think the one to try would be the Optima Model 34R Orange Top Reverse Post Battery (same specs as the 34/78 used in the article). It seems like it might solve the cable issue since the posts are on the correct side. You would still need to make a mounting plate though.
  22. Ok. I don't know if this is true or not, but I was told (by a paint guy) that "L" stands for laquer, or an "A" would stand for acrylic. He went on to say that Porsche does not use anything but laquer.
  23. On pre MY02 cars they used a separate color code for water based paint vs. conventional paint. For Ocean Blue Metallic -- 3AZ is water based paint and 3AY is conventional paint.
