  1. These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/OPC. The PCM’s require two codes, the ICS/Siemens code, and a Becker code. The ICS is the first code requested. Sorry, the only place you can get a PCM codes is from a dealer/OPC.
  2. You will need a PIWIS tester to copy the program/codes from your old KESSY/PAS to your new one.
  3. You can carefully pull the cluster and reseat all of the cables making sure they are all locked in place.
  4. This the correct place to post but I need your radio serial number. Did you rear the Lost Radio Code FAQ?
  5. Hope you are sitting down... 955 555 011 02 6K1 roof trim Sand beige US MSRP $2,439.53
  6. 996 653 101 08 Control Panel -- no price -- order by request. (original) 996 653 101 HX EFR Control panel -- US MSRP $1,240.37 If you get one at a salvage yard make sure it is from a 2001 or newer 986 (or 996).
  7. Thanks - that is great information. I am posting a copy here in case that link goes away or their site is down. mods4cars product manual.pdf
  8. Or control unit for the transfer box ? That is on the transfer box.
  9. Transfer gear control unit or the control unit for rear differential lock? I find the later -control unit for rear differential lock but not the former -- unless they are the same box.
  10. Sorry, no they never got back to me. I was an early adopter...
  11. No lights? - check the fuses. Otherwise look for loose (or taped) wiring. Beyond that you will like need Durametric or PIWIS tester.
  12. You can try re-programming but that would be an unusual cure in this case. Chances are your control module or triggering unit. Have you installed aftermarket radio/nav where perhaps a wire was pinched?
  13. I don't think the passenger airbag has a switch only the crash sensor and control box.
