  1. Yes. That should work fine if you only have one Porsche.
  2. It would be best to use a Posche specific scanner like Durametric or PIWIS before jumping to expensive conclusions. I don't think I have ever seen a Gateway fail that was not damaged by accident or water intrusion.
  3. Try 9025
  4. Try 2626
  5. I would clear all the codes and then drive the car and see what comes back. What scan tool are you using?
  6. Have you tried retraining the window? Press and hold the down button - hold it for at least 10 seconds after the window is all the way down. Then press and hold the up button - hold it for at least 10 seconds after the window is all the way up. If the window does auto up and down after that you are done -- if not, then is likely a problem with the window regulator or adjustment.
  7. A single beep means you have a zone open. You will need PIWIS or Durametric to tell you exactly which zone is open.
  8. Superseded part numbers: 9A7 007 517 00 panel screw US MSRP $0.72 each 999 591 699 01 panel nut US MSRP $0.97 each
  9. Try 4582
  10. Try 2767
  11. Try 0763
  12. Try 4818
  13. Try 2925
  14. Try 0439
  15. You have a display segment dead. All serial numbers are numbers (no letters). Try 3030
  16. Try 4309
  17. Follow the wires from the light and fan down the deck lid to the right side of the engine compartment. You will find a connector there (X23) - disconnect it and make sure the pins are good and clean.
  18. Hmm... that is where the main fuel line connects from the fuel pump.
  19. Try 5019
  20. Try 0792
  21. Try 3265
  22. Try 9842
