  1. Try 0632
  2. Try 9019
  3. Try 4315
  4. Porsche is the same on brake fluid changes - unless you live in a very humid environment.
  5. Service manuals only exist in electronic form (since 2006) inside of the PIWIS diagnostic tool. A PIWIS tool is dealer or shop only and leases for $18,000 per year (no typo). The Porsche Scheduled Maintenance Plan WWW.PORSCHE.COM
  6. Try 5459
  7. Try 1326
  8. Please verify your radio serial number using the method in the Lost Radio Code FAQ.
  9. Try 4651
  10. Please read the Lost Radio Code FAQ
  11. Suncoast do make a new key for you. Expect the new key, cutting, and programming to your car upwards of $500.
  12. Try 2674
  13. All US/Canada 996's since 2002 have PSM. Your car is a 2003 USA/Canada car according to the factory build. Did someone remove PSM? Is this the front harness or rear harness?
  14. PM me your VIN and I will look it up on the Porsche database.
  15. Are you using a Porsche specific scanner to check for fault codes?
  16. If you get wheel spin this can sometimes happen. It basically resets itself afterwords.
  17. Try 1094
  18. Fault code 1772 Pressure sensor signal wire Possible cause of fault - Short circuit to B+ in the wiring of pin 84 of the level control module - Short circuit to ground in the wiring of pin 84 of the level control module - Open circuit in the wiring of pin 84 of the level control module - Level control module receives implausible signal from pressure sensor - Pressure sensor faulty - Level control module faulty
  19. Try 4828
  20. Porsche PET parts list - we have a paid subscription.
  21. Item 2 - 996 551 211 00 Front footrest -- US MSRP $16.01 Item 3 - 999 073 062 02 Panel Screw -- US MSRP $0.89 Item 4 - n/a Panel Nut (common consumable part) Item 5 - 996 551 611 00 Cover for footrest -- US MSRP $15.02 Item 6 - 999 919 161 09 Fillister head bolt -- US MSRP $1.00
  22. Try 1287
  23. Which item(s) do you need?
