  1. Try 6094
  2. There are only two hex bolts that need be removed. Chances are the o-ring is leaking and must be replaced. The housing gets a new o-ring and spray-on sealant. Do not over tighten the two hex bolts - 6 ftlb. max.
  3. The clutch slave cylinder bleeds through the brake reservoir. Follow the procedure for the 996 series cars (it is the same) for proper bleeding of the clutch slave. Optional Clutch Bleeding (near the end)
  4. Try 8452
  5. Hmm... did someone upgrade the brakes to the 92A (2011 and later) brakes? Either way - yes, the calipers need to come off.
  6. The bar code means nothing to the radio code - did you use the procedure in the Lost Radio code FAQ to get the serial number to display on the screen?
  7. Did you use the procedure in the Lost Radio Code FAQ to get the correct serial number of your radio? If not, then please do so and report the correct serial number here.
  8. Try 8642
  9. Try 9780
  10. Try 7104
  11. Did you use the procedure in the Lost Radio Code FAQ to get the correct serial number of your radio? If not, then please do so and report the correct serial number here.
  12. Try 8642
  13. Yes, only a PIWIS can program keys. I would contact Porsche Cars North America on Monday at 1-800-767-7243. Explain your situation and ask them help.
  14. Try 0784
  15. Did you use the procedure in the Lost Radio Code FAQ to get the correct serial number of your radio? If not, then please do so and report the correct serial number here.
  16. Try 3206
  17. Try 0473
  18. Try 4213
  19. As a daily driver I would stick with the factory pads and rotors. Other pads may produce less dust but more noise and potentially more wear on the rotors. As I said for street use I would stick with the factory parts.
  20. I already replied to this....
  21. Yes, the black should be the same as long as there is no sun or other weather damage..
  22. It appears from the part list the seats are the same physically - coupe to coupe and cab to cab. Of course there are a wide variety of options leatherette (plus colors) and leather (plus colors) and draped leather (plus colors).
  23. Sorry, try 2615
  24. You obviously did not read the Lost Radio Code FAQ... " Can you give me a code for my PCM?These units are manufactured jointly by Siemens and Becker, and the only place where you can get the codes required is from the dealer/ OPC. The PCM’s require two codes, the ICS/Siemens code and a Becker code. The ICS is the first code requested.Sorry, the only place you can get a PCM code is from a dealer/ OPC. "
  25. Try 7371
